Tailgate hard to open
Discussion in '2.5 Gen Tundras (2014-2021)' started by odin1701, Feb 1, 2022.
  1. Feb 1, 2022 at 7:53 AM
    odin1701
    odin1701 [OP] New Member
    2021 Tundra LTD TRD OR MGM
    So one annoying thing is that my tailgate is really hard to open. You have to really pull on the handle hard. I'm assuming this is not normal. There is a factory installed power tailgate lock in it which maybe needs adjustment but not sure. Anyone else have similar experience?
  2. Feb 1, 2022 at 7:59 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You may have an alignment issue with the retention hooks that the truck bed locks onto when you close it. try checking the alignment on them. My old ranger had this, I had to jiggle the handle while opening and when i adjusted the hooks, maybe a 1/8" it would open easily.
  3. Feb 1, 2022 at 8:01 AM
    odin1701
    Hmm, not sure how to adjust that. I'll have to take a look but we're getting a snowstorm later and it's cold lol so maybe next week.
  4. Feb 1, 2022 at 8:09 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Push the tailgate in when you pull on the handle. If it's easier to pull the handle to open, you have an alignment issue like @MadMaxCanon said. Adjustment is super simple
    Black Wolf likes this.
  5. Feb 1, 2022 at 8:16 AM
    odin1701
    Cool thanks, I'll try this.
    831Tun[QUOTED] likes this.
  6. Feb 1, 2022 at 11:39 AM
    odin1701
    This is definitely the issue. Opens much easier when I push in. Do you adjust the latch or the catch on the bedside? The latch looks like it would be a pain to adjust.
  7. Feb 1, 2022 at 2:02 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Honestly don't remember but I think the latch and it's a T40 bit.
  8. Feb 1, 2022 at 2:41 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I would say loosen the catches, close the tailgate with them loose and then that will tell you where they need to be, then tighten them while the tailgate is closed.
  9. Feb 1, 2022 at 7:03 PM
    IA_Tundra
    IA_Tundra New Member
    Gator Mats
    I had a similar issue. I took the plate off the back of the tailgate and cleaned the grime off the handle and it is easier to open. My kids even think it’s a new part but I just cleaned it.
    astro-jason likes this.
  10. Apr 9, 2023 at 4:06 PM
    RagElWa
    RagElWa New Member
    James
    '23 Platinum Crewcab 4x4 HV 5.5,
    Manual delete of new-truck smell. Dirt and grease accents to the leather
    How?
  11. Apr 9, 2023 at 4:16 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Open the tailgate, loosen the catches on the bedsides and pull 'em toward the back a little
  12. Apr 9, 2023 at 6:14 PM
    RagElWa
    RagElWa New Member
    James
    831tun I was stumped on how to tighten them with the tailgate closed
    Mine sticks on the right side. I though it was the decked hook pulling the tower, but not really. When I push into the catches, I get little resistance on the left, but almost a bind on the right. I will try adjusting tommorow. Thanks
    831Tun likes this.
