Tailgate handle
Discussion in '2nd Gen Tundras (2007-2013)' started by TundraTRD08, Jul 13, 2022.
  1. Jul 13, 2022 at 8:00 AM
    TundraTRD08
    TundraTRD08 [OP] Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    Does anyone know if the make a tailgate latch that can actually handle working for a farm truck? Wondering if they make metal ones. I’ve broken 2 plastic ones already and I’m tired of it.
  2. Jul 13, 2022 at 8:02 AM
    TundraTRD08
    Wesley
    And yes, I’m easy on them and do all of it’s little tricks to make it open better, such as push in on the tailgate and shake it a little bit.
  3. Jul 13, 2022 at 8:04 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I haven't found one. I've broken two in two years also, the plastic gets brittle and fails (plus in general is kind of a bad design).
    TundraTRD08[OP] likes this.
  4. Jul 13, 2022 at 8:08 AM
    TundraTRD08
    Wesley
    I noticed this, my tailgate cover broke off so I’m using a long screwdriver to move the mechanism. It moves very nicely, and is lubricated frequently, it’s just they they used a poor design. Also, I wish that they didn’t feel cheap. My dad has a GMC Denali 2500 and there are no tricks or gimmicks to getting it to open, and it is SO EASY to open it. Tundras on the other hand are just really stiff for some reason.
  5. Jul 13, 2022 at 8:13 AM
    snivilous
    SW UT
    I had been thinking about machining a handle last time it broke but it's not the simplest part. I've had the little post thing on the back rip off and had the hand hold disintegrate too. It seems dependent on brands which one lasts longer since the second one that broke lasted about 3 months.
  6. Jul 13, 2022 at 8:19 AM
    TundraTRD08
    Wesley
    Noted. I’m sure that you get what you pay for. Mine broke going halfway up to the metal rod that it pushes on, so somewhere along the plastic part. I’ve thought of fabricating my own too, but I don’t know how it would work out.
  7. Jul 21, 2022 at 8:54 AM
    Uncledan
    Uncledan New Member
    Following
  8. Jul 21, 2022 at 8:57 AM
    TundraTRD08
    Wesley
    Looks like plastic is about the only option here. I guess just keep replacing them as they break.:frusty:
  9. Jul 23, 2022 at 2:05 AM
    blenton
    blenton New Member
    My tailgate was getting sticky and harder to open a while back. It felt like I was going to break the handle prying on it. The tailgate was also having a hard time latching all the way in the winter. I ended up dropping the tailgate down and pulling off the access panel (8 or 10 torx screws - T55 maybe?). The linkage didn't look horrible but it was dusted and coated with dirt and sawdust. I inspected the handle itself and found the same thing, but noticed how much leverage the outside handle gives to the mechanicals inside that move the linkage. I gave them a good, simple cleaning, then lubed everything with some grease from my grease gun for the u joints, paying close attention to parts that slid over other parts including the latches at the edges of the tailgate.
    It now opens with one finger. Feels like butter. I figured I was just going to make it serviceable until warmer weather arrived and it would be easier to replace some parts. But, seriously, it feels easier to open now than when it was new. So I'd clean and lube the tailgate latches before placing all the blame on the handle. My tailgate gets opened every day - most days several times. Maybe even as much as the driver's door. I thought I took some pictures of it, but I don't see them. I'll post them if I can find them.
