Tailgate doesn't feel secure
Discussion in '1st Gen Tundras (2000-2006)' started by Rusty Shacklefurt, Feb 16, 2021.
  1. Feb 16, 2021 at 12:37 PM
    Rusty Shacklefurt
    Rusty Shacklefurt [OP] New Member
    NW Arkansas
    2003 Black Access Cab
    Hi all, hope I can explain this well. I've noticed recently that when opening my tailgate the handle will stay open, as if there is no tension in the cable and when I close it it sometimes feels as if one of the latches doesn't secure. I got my bed Rhino lined a few weeks ago but I'm not sure if the issue arose before or after, unfortunately.
    Does anyone have any advice as to what the issue might be?
  2. Feb 16, 2021 at 12:51 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You should give it a compliment once in a while, tell it how slim it looks and how its in great shape for its age. :D
  3. Feb 16, 2021 at 12:59 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Take off the access panel, 8x or so torx head screws and investigate. Mine was sticking recently. Got in and cleaned it up and lubricated all the moving parts. Good as new now.
  4. Feb 16, 2021 at 1:37 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    This . . .^^^^^^^
  5. Feb 16, 2021 at 2:00 PM
    Rusty Shacklefurt
    NW Arkansas
    Righteous. Thanks. Do you have a degreaser and lube you recommend? I assume that's what you mean by "cleaned up"?
    bmc02[QUOTED] likes this.
  6. Feb 16, 2021 at 2:08 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    I hit the moving parts with some carb or brake cleaner or something similar to clean it up and get the grime off. Both in the middle mechanism and the outside strikers. For lube I believe I used ample amount of white lithium grease spray. Ran the action a few times then hit it again. Cleaned up any over spray and buttoned her back up.
    Darkness and des2mtn like this.
  7. Feb 16, 2021 at 2:32 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    This is some solid advice.
    Unrelated, but my tailgate got to where it wouldn't open without a lot of effort. I took my panel off and turns out the cables were worn out and bending inside. Replaced both of them and the tailgate opens and shuts very smooth.
    HBTundra, bmc02[QUOTED] and Darkness like this.
  8. Feb 16, 2021 at 5:28 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Funny, I just did this today, my mechanism was so stiff I was afraid something would break soon. I used a plastic safe contact cleaner (lots of plastic bits in there) and a tooth bush to clean the gunk. Then a small amount of a lubricating spray lube (not WD-40) on the parts that pivot and move, and some light weight lithium grease on the latching bits. Easy and smooth to open now, just one finger needed. Also, the rods or linkage that run to the latches, run through plastic clips to guide them, and since they slide through the clips when you open the gate i put a small bit of grease there as well so the linkage won't drag. It all added up to a smooth action.
  9. Feb 16, 2021 at 6:55 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Had same thing after my Line X
    Somehow they got some spray on the rods. And the rods where rubbing against something.
    Don't remember exactly, its been awhile. But was easy fit once take of the tailgate service panel. Also if it works great with the panel off. You know the rods are bent and it is rubbing against the panel.
    Rusty Shacklefurt[OP] likes this.
  10. Feb 16, 2021 at 7:36 PM
    Rusty Shacklefurt
    NW Arkansas
    So the normal tailgate servicing removed the residue spray?
  11. Feb 17, 2021 at 4:19 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    FWIW: WD-40 is a great cleaner for an application like this. Then lubricate with your grease of choice.
    des2mtn likes this.
