Tail lights out?
Discussion in '2nd Gen Tundras (2007-2013)' started by DesertToy, Sep 7, 2015.
  1. Sep 7, 2015 at 9:22 PM
    DesertToy
    DesertToy [OP] New Member
    Ben
    Idaho
    2010 Limited Tundra Crew Max
    Leveled, Peragon bed cover. Yep that's it!
    Just yesterday I was informed my tail lights were out. So of course I check the bulbs and they are good, I checked the fuse and it's good. Anyone have any suggestions?
  2. Sep 7, 2015 at 9:50 PM
    Hmmmm...something like that is usually a fuse...ground fault?
  3. Sep 8, 2015 at 7:46 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Check the brake light switch at the brake pedal. Connection and adjustment.
  4. Sep 8, 2015 at 7:18 PM
    DesertToy
    Ben
    Idaho
    I've checked all the possible fuses, even put new lights in and still nothing. I've made an appointment at the Toyota dealer to be fixed. It's weird my brake lights work when pressed which is the same bulb.
  5. Sep 8, 2015 at 8:37 PM
    DesertToy
    Ben
    Idaho
    After doing more research on this I had no idea about the little fuse box right behind the hood release latch. There is a fuse labeled Tail 15amp fuse and this was blown. They are working!!
    chphilo and T-Rex266 like this.
  6. Sep 8, 2015 at 8:47 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Glad you found the problem.
  7. Sep 9, 2015 at 4:53 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Glad that you found your problem. I must not be very observant. I didn't notice any fuse box behind the hood release latch. Now I know.
  8. Sep 9, 2015 at 9:31 PM
    DesertToy
    Ben
    Idaho
    I'm glad I did as well. I had no idea it was there but there it was. Hopefully this helps others with similar issues.
