Tail lights out fuse not blown
Discussion in 'General Tundra Discussion' started by BOBONTUESDAY, Feb 9, 2019.
  1. Feb 9, 2019 at 4:22 PM
    BOBONTUESDAY
    BOBONTUESDAY [OP] Grocery Getter
    2016 Limited Trd
    2016 Toyota tundra taillights fuse not blown but the lights are out
    SoCal619 likes this.
  2. Feb 9, 2019 at 5:16 PM
    BOBONTUESDAY
    2016 Limited Trd
    Yeah fuse is fine I swapped it out still no juice
  3. Feb 9, 2019 at 5:43 PM
    BOBONTUESDAY
    2016 Limited Trd
    I tested the tail lights they work but no juice from the twilight plugs or the license plate lights.
  4. Feb 9, 2019 at 6:04 PM
    15whtrd
    15whtrd Mr. Blonde
    You checked all the fuses for sure?
    TXRailRoadBandit73 likes this.
  5. Feb 9, 2019 at 6:27 PM
    BOBONTUESDAY
    2016 Limited Trd
    Are there any other fuses that could control the taillights besides the one labeled tail lights?
  6. Feb 9, 2019 at 6:33 PM
    15whtrd
    15whtrd Mr. Blonde
    I'm not positive. But check anything remotely related. Check the ones under the driver kick. I have a fuse tester that lights up if the fuse is good so I don’t have to pull them out to check.
  7. Feb 9, 2019 at 6:41 PM
    BOBONTUESDAY
    2016 Limited Trd
    I checked every fuse under the hood all looked good I'm about to go check every single one under the dash. I already confirmed the one labeled tailight under the dash is not burnt and I still swapped it for a new fuse still no juice.
    15whtrd likes this.
  8. Feb 9, 2019 at 6:42 PM
    atxtundra
    atxtundra New Member
    Check the 15a STOP fuse under the hood.
    TundraTunners and 15whtrd like this.
  9. Feb 9, 2019 at 6:57 PM
    BOBONTUESDAY
    2016 Limited Trd
    That s the brake light fuse changed it no difference still no tail lights
    15whtrd likes this.
  10. Feb 9, 2019 at 7:08 PM
    BOBONTUESDAY
    2016 Limited Trd
    Checked every fuse in the truck every fuse is good. The tailights work powered off of 12 volts so it's not the tailights. The wire that goes to the tailights has no juice. There is no crossion on the plugs. The brake lights, blinkers and drls headlights ECT work trail plug works.
    I'm getting to the point I might cut the tailight wires and wire it to the trailer plug harness.
  11. Feb 9, 2019 at 7:22 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Give a push on all the relays in the fuse box under the hood, worth a try. Have you done ANYTHING electrical lately? *Grasping at straws*
    15whtrd likes this.
  12. Feb 9, 2019 at 7:33 PM
    BOBONTUESDAY
    2016 Limited Trd
    Already did the relay push nothing happened.
    Haven't done anything electrical
  13. Feb 9, 2019 at 7:34 PM
    BOBONTUESDAY
    2016 Limited Trd
    I said fuck it and wired it through the trailerlight plug spliced the license plate light got tailights for now. Fuck it it'll work for now.
  14. Feb 9, 2019 at 7:36 PM
    15whtrd
    15whtrd Mr. Blonde
    Are you getting power to the fuse?
  15. Feb 9, 2019 at 9:43 PM
    BOBONTUESDAY
    2016 Limited Trd
    Fuse has power
    15whtrd[QUOTED] likes this.
  16. Feb 9, 2019 at 9:44 PM
    BOBONTUESDAY
    2016 Limited Trd
    Lights all work just no juice to the wire for the tail lights.
  17. Feb 9, 2019 at 9:49 PM
    BOBONTUESDAY
    2016 Limited Trd
    Oh but now my fog lights stopped working. Lol
  18. Feb 9, 2019 at 9:50 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Under warranty still? I guess it's too late for that since you cut the wires already.
    So you're saying you 1) confirmed you have power at the fuse? 2) hooked lights directly to 12v and they work?
    Have you done any work at all to the truck? The issue would have to be with the wire between the fuse and the light. Must be pinched , cut, corroded.
  19. Feb 9, 2019 at 9:53 PM
    BOBONTUESDAY
    2016 Limited Trd
    182k way past warranty.
    Fuse has power
    Tailights work from a 12volt power source.
    Ohm meter doesn't show anything for the tailights wire.
    No work done to the truck recently.
    Tailights worked fine last night.
    I agree there must be a wire pinched or corroded somewhere in the line.
    But my trucks way to caked in snow to see shit right now and I'm out of town so there's no where to thaw it out tonight.
  20. Feb 9, 2019 at 10:00 PM
    Pudge
    CT
    Sorry man that sucks. I wonder if the snow or ice has something to do with it. Living in new England I can sympathize with you on winter car repairs. It suck just being so cold never mind dealing with snow, ice, sand a salt all over the place
  21. Feb 10, 2019 at 5:58 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Is it possible the multi-function lever is going bad?
    Black Wolf and Watt maker like this.
  22. Feb 10, 2019 at 7:16 AM
    15whtrd
    15whtrd Mr. Blonde
    Just so we’re clear, not one light will light up on the tail lights? No turn signal, no running lights, no reverse lights, no brake lights?
  23. Feb 10, 2019 at 7:21 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    He's said he has Stop, Turn and Reverse, No Tail.
    Beesta likes this.
  24. Feb 10, 2019 at 7:28 AM
    15whtrd
    15whtrd Mr. Blonde
    I guess it must be hidden in his explanation, it wasn’t clear to me whether it was completely dead or just one function, all I noticed was tail lights not working. To me that sounds like none of it is working.
    I'm still working on my morning coffee.
    Black Wolf and NewImprovedRon like this.
  25. Feb 10, 2019 at 7:59 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, me too. Cuppa for the win. There's an understandable amount of frustration in his posts that require a little more study before coffee.
  26. Feb 10, 2019 at 8:01 AM
    BOBONTUESDAY
    2016 Limited Trd
    After looking at that pdf it tells me that the tailights fuse controls the trailer tail lights also but if does not because my trailer tails work fine.
    I checked every fuse with a tester every single one checked out fine and I went over ever fuse more than once.
    15whtrd likes this.
  27. Feb 10, 2019 at 8:04 AM
    BOBONTUESDAY
    2016 Limited Trd
    Turn, reverse and brake work just no running lights hence no tailights sorry if it wasn't clear I was pretty pissed and cold last night.
    Yes just no tail.
    I just go this rig home lol.
    Yeah just no tail/running light whatever you want to call it.
    No power to the taillight wire that is my issue here and I can't seem to figure out what the hell happened.
  28. Feb 10, 2019 at 8:06 AM
    15whtrd
    15whtrd Mr. Blonde
    OK so if the trailer harness is working and it’s on the same fuses as the tail lights, I think that narrows it down to something going on at the rear of the truck. Am I wrong? My next thought would be, does the trailer harness run all the way up to the fuse box or does it splice into the tail light wires at some point on its way to the rear of the truck.
  29. Feb 10, 2019 at 8:06 AM
    duece292
    Greg
    Green Bay, WI
    I'm almost a full pot in, almost time to temper that a bloody Mary. I could be totally wrong but I think the headlight switch is the culprit. If brakes and turns work but no tails and now no fogs, all of that is contained in this one multi-function switch. s-l300.jpg
    equin, 15whtrd and Wynnded like this.
  30. Feb 10, 2019 at 8:06 AM
    BOBONTUESDAY
    2016 Limited Trd
    I'm sick of this snow it's been horrible this year and the shit they put on the roads does not help. And being negative temps all night doesn't help either.
