Tail light fuse keeps blowing
Discussion in '2.5 Gen Tundras (2014-2021)' started by PhilipA, Aug 4, 2019.
  1. Aug 4, 2019 at 11:36 AM
    PhilipA
    PhilipA [OP] New Member
    Philip
    2014 Toyota Tundra Extra Cab
    obviously I have an electrical short somewhere that’s causing my tail light fuse to blow. Has this happened to you and where did you find the short?
    Thanks in advance
    Phil
  2. Aug 4, 2019 at 11:48 AM
    tubal
    tubal New Member
    SLC, UT
    First thing to check would be the bulbs. Then the trailer light assembly. Then the wiring underneath to see if anything has pinched or cut it.
    Beesta and (deleted member) like this.
  3. Sep 6, 2020 at 1:21 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Got same issue last night ... did you happen to figure this out ..? Thanks
  4. Sep 6, 2020 at 4:51 AM
    Welcome from NY.
    Do you have factory taillights?
    Like mentioned check those 2 things first.
  5. Sep 6, 2020 at 4:52 AM
    If you still have the factory taillights I would go to the dealership because you are still under warranty.
    NewImprovedRon likes this.
  6. Sep 6, 2020 at 5:44 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    No but i removed the LED tails and have the bulb just hanging on both side and still blowing fuse.. thanks for the help
  7. Sep 6, 2020 at 5:50 AM
    Not understanding your reply.
    You put LED bulbs in? If so check the wire on the base of the LED bulb and make sure it is straight and only touching the connector, sometimes the wire is touching more than the connector and that creates a short.
  8. Sep 6, 2020 at 6:27 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Yes i have ... i even had all LED bulbs pulled out .. reverse, brake and license plates removed ... i still halogen on my rear turn signal ... with no bulbs plugged in as soon as i put a 10 amp mini and turn on parking lights im blowing fuse right away ...
  9. Sep 6, 2020 at 6:49 AM
    Sounds light a pinched wire or a bad socket.
    I would remove each parking light and try 1 at a time to narrow down the bad socket/wire.
  10. Sep 6, 2020 at 6:54 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Thanks man ..i appreciate the help
    Jim LE 1301 likes this.
  11. Sep 6, 2020 at 6:58 AM
    :hattip:
  12. Sep 6, 2020 at 7:34 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Yeah im really trying to avoid to take her to the dealer but i don't want to start hacking my sockets at the same time.... thats what warranty is for right ... thanks Jim
  13. Sep 6, 2020 at 8:47 AM
    :hattip:
  14. Sep 6, 2020 at 5:10 PM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Hey Jim .. just want to let you know that i’ve figured it out... it was the patch harness for my NSV headlight kit ..... now i need get with NSV for this issue .. thanks
  15. Sep 6, 2020 at 5:36 PM
    :thumbsup:
    I remember a few other members with the NSV having that same issue.
    Glad you figured it out.
    Beesta[QUOTED] likes this.
  16. Dec 24, 2020 at 5:53 PM
    Lugnuts2020
    Lugnuts2020 New Member
    2018 crew max
    Hey did you happen to figure out the issue with your taillights and nsv? I just installed one and I’m having the same issue.
    Thanks
  17. Jan 13, 2021 at 7:51 PM
    SkySoldier
    SkySoldier New Member
    2019 Tundra
    The solution regarding the fix for the NSV light kit would very beneficial, please share with us all. Many thanks in advance
  18. Jan 14, 2021 at 1:23 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Usually issues come down to 2 things, one if you have corrected the turn signal wiring prior to nsv light bar install, you have to return the wiring back to original, otherwise the nsv harness won't get right inputs, and you'll blow fuses. The second is the final step of how the nsv plug is wired into the turn signal, depending on your truck, you may or may not have to cut a wire, blue if I remember right. Everything else is factory plugs. Sure NSV is aware of the turn signal problems by now.
    SkySoldier likes this.
  19. Jan 14, 2021 at 1:34 PM
    SkySoldier
    2019 Tundra
    Greatly appreciate the information, I do recall that the connector to turn signal required a wire to be cut and if I'm not mistaken unpinned and relocated. Again, thanks for providing some much needed insight to this issue. Be Safe' :hattip:
  20. Mar 17, 2021 at 10:13 AM
    nate247m
    nate247m New Member
    2018 Tundra CM
    What ended up being the problem with the patch harness?
  21. Oct 6, 2021 at 11:25 AM
    Lance
    Lance New Member
    Lance
    NSV LIGHT BAR
    I installed an NSV lightbar on a 2020 Tundra. Blew a fuse 10a. No tail and license plate lights. Did have the recall done prior to the light bar. Now FIXED.
    SWITCHED the NSV T-harness at all four connectors. BLUE WIRE & WHITE WIRE, trade places. Then at the headlight connection I de-pinned the WHITE wire which takes care of the driver side parking light being on all the time at the indicator except at the OFF position.
  22. Nov 28, 2021 at 9:19 PM
    Rlloyd18
    Rlloyd18 New Member
    Rick
    2020 Cement Tundra 4x4
    What do you mean by switched all 4 connectors? I was told by the Nsv rep that I only had to switch the 2 at the headlight that connect the blinker.
  23. Nov 29, 2021 at 8:49 AM
    Lance
    Lance New Member
    Lance
    NSV LIGHT BAR
  24. Mar 18, 2023 at 9:40 PM
    JekyllTheRipper
    JekyllTheRipper New Member
    Michael
    2018 tundra crewmax
    Are canopy, prinsu roof rack on cab and canopy, NSV hood bulge light bar, LED interior light kit, diode dynamics fog lights, SDHQ switch panel center console, 10 inch sub box behind back seats, huracan fabrication tailgate storage, storage box under back seats
    Hey, I've got the NSV hood bulge kit installed as well, during the installation I told was told to cut the wire, but when I did, my front blinkers quit working, so I reconnected that wire and I didn't have any issues for 2 months, until 2 days ago when my tail lights quit working and my fuse kept instantly blowing. I'm not sure what your fix was though, could you help me??
