Tacoma to Tundra differential swap
Discussion in '1st Gen Tundras (2000-2006)' started by mertintech, Apr 16, 2021.
  1. Apr 16, 2021 at 8:46 PM
    mertintech
    mertintech [OP] New Member
    ross
    2001 tunda
    Want to know if I can use rear axle out of 2000 Tacoma in my 2001 tundra mine is 3.91axle none locker 4.7 engine
  2. Apr 16, 2021 at 8:46 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  3. Apr 16, 2021 at 9:00 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Everything I have seen/read is no. I can’t remember specifics though as to why they will not fit.
  4. Apr 16, 2021 at 10:44 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    The Tundra diff housing is larger and the 3rd member is reinforced. Length may be different.
    You could possibly swap complete 3rds but I can't confirm if they will work (axle spline size may be different, etc).
    Same size R&P iirc and you can possibly swap a locker/LSD from one 3rd member to another if axle spline size is the same.
  5. Apr 17, 2021 at 6:05 AM
    Professional Hand Model
    Hand Protectors
    Yeah. He did both the front and rear diffs swap from a Taco.
  6. Apr 17, 2021 at 6:09 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    They're different widths, the Tundra axle housings being wider making the Tacoma axles too short. The thirds are swapable though, I've done it a couple of times.
  7. Apr 17, 2021 at 7:34 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    The 3rd Members are identical, I have a 4.56 3rd member in my truck from a 2.7L Tacoma.
    Housings are different, axle shafts are longer, so you’ll need to keep your Tundra housing and axle, but the 3rd member is bolt in.
    just make sure your gear ratios match.
    Darkness likes this.
  8. Apr 17, 2021 at 7:43 AM
    Conversely, A Tundra rear axle is the perfect swap for a widebody Tacoma, or for that "froggy" look in the rear.:mudding:
    Full disclaimer: do not try this at home.
    speedtre and Darkness like this.
  9. Apr 17, 2021 at 7:53 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Too late...
    MS22, speedtre, onesojourner and 5 others like this.
  10. Apr 17, 2021 at 8:19 AM
    Ha, I would have went for the longer shocks though.
    Beefnbread, N84434, Darkness and 2 others like this.
  11. Apr 17, 2021 at 1:30 PM
    mertintech
    ross
    2001 tunda
    So just want to confirm my third member is not a locker but the Tacoma is will that make any difference or are the 3rd members same size lockeror not
  12. Apr 17, 2021 at 1:51 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Knowing if the Tacoma locker is an e-locker is important, according to this:
    Toyota Electric-Locking Differentials
  13. Apr 17, 2021 at 3:17 PM
    Hand Protectors
    Which one of these lockers is most like the OEM LSD from 2002 Tundras?
    East Coast Gears sells 3rd Members (rebuilt) and you can add a locker option. The LSD has done me good since new so figuring something along the same option.
    speedtre likes this.
  14. Apr 17, 2021 at 4:53 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    The locker Tacomas are an entirely different differential. They will NOT work in a Tundra.
    speedtre and Wynnded like this.
  15. Apr 17, 2021 at 5:57 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    All of them EXCEPT the true trac are lockers and will most likely have much harsher engagement than a LSD.
    The true trac is a gear driven (torsen) LSD, which works good unless one wheel has zero traction. IE: one wheel is airborne, one on ice and the other on pavement (or super slick mud). Then it'll act like an open diff.
  16. Apr 17, 2021 at 7:03 PM
    speedtre
    speedtre New Member
    Inland Northwest
    All true....but this can be overcome with a little deft working of the brakes in that scenario...
  17. Apr 18, 2021 at 7:00 AM
    Poor mans LSD = some light to moderate parking brake application in low traction situations.
