Tacoma battery ah
Discussion in 'Other Toyota Vehicles' started by BlakeRamon, Nov 7, 2019.
  1. Nov 7, 2019 at 12:44 PM
    BlakeRamon
    BlakeRamon [OP] New Member
    I have a Toyota battery for my Toyota Tacoma. Battery size is 27F with 700 CCA.
    I had to charge the battery recently, and the new battery charger I bought wanted me to enter the ah. My owner's manual for the charger said that the ah value is on the battery label, but I did not see it. I called the parts store at the Toyota where I bought it, and he did not know what the ah would be.
    I ended up setting the ah to 60. It took over 24 hours to charge my battery, and it wasn't quite done when I took it off the charger.
  2. Nov 7, 2019 at 1:46 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    No help on the ah, but what charger do you have that asks for that info before charging it?????? Sounds crazy.
    YardBird likes this.
  3. Nov 7, 2019 at 1:50 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Maybe its asking you what amp you want to charge it at.
  4. Nov 7, 2019 at 2:34 PM
    Danimal86
    Daniel
    Sacramento, CA
    I hope he didn't charge it at 60amps :eek::eek::eek:
  5. Nov 7, 2019 at 2:54 PM
    Seanc770
    Seanc770 New Member
    N. Ga
    2016 Tundra xp blazing blue pearl
    Ah= amps per hour
  6. Nov 7, 2019 at 3:33 PM
    BlakeRamon
    The charger is an Ampeak 2/8/15A smart battery charger. I charged my battery with 8 amps and the Ah set at 65 and it took over 24 hours. I found a little bit of information on Ah, but not much. Next time I will use 100 Ah, as that is what an example I found on the Internet uses with a battery my size. Thanks for the posts.
