Taco Tunes vs. Tech 12 volt vs. another PNP
Discussion in 'Audio & Video' started by NorCal Dubs, Apr 16, 2018.
  1. Apr 16, 2018 at 1:56 PM
    NorCal Dubs
    NorCal Dubs [OP] New Member
    Clay
    2016 Gray Tundra Platinum
    6” Pro Comp lift, 20” lrg rims, 37X12.5 Toyo Open Country, backflip t-cover, amp steps, and a tinted sunroof (best thing EVER)
    I don't want to get rid of my stock HU. I have a platinum CM with JBL. My audio install knowledge is not great but did some before about 20 years ago so I am not a fresh beginner but for sure not an expert.
    Has anyone used Taco Tunes, Tech12 volt or another pnp?
    I am curious if the Taco Tunes 1b is sufficient, but the SQ1 looks like a major upgrade with the 2 amps and recurve. I like the 2 10s idea. I don't need crazy sound but I do enjoy music with a little thump. I am about to buy something and considering installing myself unless you guys think it is a lot more difficult than it is made out to be.
    Thanks for helping...
  2. Apr 16, 2018 at 2:05 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    NorCal Dubs[OP] and smslavin like this.
  3. Apr 16, 2018 at 2:06 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i just ordered some stuff from james at Tech12Volts. good guy. super helpful. i didn't get a pnp setup but he did make sure i'd have all the harness i'd need.
    NorCal Dubs[OP] and 831Tun like this.
  4. Apr 16, 2018 at 6:04 PM
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    Another vote for tech12volt, and like you limited install experience from 20years ago. His install sheet seems pretty straight forward to me. Plenty of youtube videos to help with removing panels/trim/seats, I bought a cheap kit off Amazon for removing trim without scratching the hell out of the plastic. Highly recommend bc the interior of these trucks scratch if you look at them funny. Im just waiting on my soundskins to come in before I install so I only have to remove the panels and seats once (mainly from a lack of free time than difficulty) I went with a similar JL set up as some of the build threads on here have.
    NorCal Dubs[OP] likes this.
  5. Apr 16, 2018 at 10:05 PM
    NorCal Dubs
    Clay
    Great idea! Thank you!!! The JL stuff look awesome. I am looking to spend $1500ish and the JL stealth box is $1100. Just don’t have the funds rights now.
  6. Apr 17, 2018 at 2:56 AM
    Beerdude77
    My budget was similar and I got all this from tech12volt: a custom ported sub box, 2 JL 10w1's, 4 JL C2650's, 5 channel JL amp, JL Bass knob, amp power wiring kit, wiring harnesses for door speakers and factory amp so no cutting any wires for install and I am keeping the oem head unit, and speaker mounts for all 4 doors...Its your money but I couldn't justify sinking $1100 into just the subs alone when I could get all this and it fit my budget. Just email James and tell him what you are looking for and how much you want to spend and he'll get you a quote in about a day.
    dxiong0629 likes this.
  7. Apr 17, 2018 at 3:27 AM
    Tundramoney
    Tundramoney Old school
    Earth
    The factory head unit has to go!
  8. Apr 17, 2018 at 3:51 AM
    Cfincke
    San Antonio
    I got all my JL speakers, amp, Fix86, speaker adapters, and harness from James at tech12volts.
    FyI - he may have found a module to allow the removal of the factory amp while keeping the head unit in JBL entune equipped trucks.
    afbatts and Pudge like this.
  9. Apr 17, 2018 at 3:58 AM
    Beerdude77
    It will be difficult to keep that budget and replace the head unit. A sacrifice of either quality or equipment would have to occur. That said the head unit does suck and I plan to replace it in the future lol.
  10. Apr 17, 2018 at 4:04 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    How do I get in contact with James? Is he in the forum or through another means? Thank you
  11. Apr 17, 2018 at 4:34 AM
    Beerdude77
    On the "Contact Us" section on his online store website. Takes about a day to hear back
  12. Apr 17, 2018 at 4:38 AM
    Tundramoney
    Earth
    I tried to save the head unit and did the same thing all with new equipment never sounded audiofile quality until changing head unit.
    1UPPER likes this.
  13. Apr 17, 2018 at 4:47 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
  14. Apr 17, 2018 at 4:48 AM
    seniramsu
    Nate
    VA
    Good deal. Thank you
  15. Apr 17, 2018 at 5:24 AM
    smooosh
    smooosh This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    You don’t need a signal processor if you change the head unit so that offsets the price a bit.
    Tundramoney likes this.
  16. Apr 17, 2018 at 7:09 AM
    Danimal86
    Daniel
    Sacramento, CA
    I went through the same thought process. I ended up getting a "scratch/dent" from crutchfield for cheap. If i didn't i would have have James make me a box with the same jl subs that are in the stealth enclosure, and saved a good chunk of change.
    Here's what i did. Figure out what gear you want, and shoot James an email and he will give you prices. be prepared for some short responses.
    I'll tag @BOOMHAUER@TECH12VOLTS in case he still comes on here.
  17. Apr 17, 2018 at 7:24 AM
    smooosh
    Ongoing project
    FYI the stealth enclosure uses JL 10w3's. Most of the build threads i have seen here with a cheaper box are using JL 10w1's. They are not the same. They are cheaper because they are $80 cheaper per speaker. the 3 handles almost double the wattage that the 1 handles and I'm pretty sure the 3 is dual voice coils and the 1 is a single.
    You can buy the speakers and a custom box separate and get it cheaper then the stealth box. I think mine was around $700 with 2 JL 10w3's and a custom box at the shop i bought my equipment from.
  18. Apr 17, 2018 at 7:52 AM
    Danimal86
    Daniel
    Sacramento, CA
    I had james give me a quote on how much it would be for the same speakers (https://www.crutchfield.com/p_13610...MIr_To5cbB2gIVgq_sCh3EWwg7EAQYAiABEgIeqvD_BwE)
    but in a box he made instead of the fiberglass stealth box. It was going to save a couple hundred bucks, but i already had the stealth.
    Did you get the full size w3's in yours or is it the slimline?
  19. Apr 17, 2018 at 7:55 AM
    smooosh
    Ongoing project
  20. Apr 17, 2018 at 7:56 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    ive used tech12volt also for 2 different rides. would be my go to again.
  21. Apr 17, 2018 at 8:10 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Oh really? This would be amazing
    Cfincke[QUOTED] likes this.
  22. Apr 17, 2018 at 8:29 AM
    seniramsu
    Nate
    VA
    Haha.. after seeing how passionate Sean was about this subject I knew he would comment!!!! :ballchain::ballchain:
    Sunnier and Pudge[QUOTED] like this.
  23. Apr 17, 2018 at 9:24 AM
    Cfincke
    San Antonio
    He posted about it on FB last week. I have not seen a post about it being successful yet.
    Pudge[QUOTED] likes this.
  24. Apr 17, 2018 at 9:25 AM
    Danimal86
    Daniel
    Sacramento, CA
    Link?
    Pudge is going to be first in line.
    Pudge likes this.
  25. Apr 17, 2018 at 9:29 AM
    Cfincke
    San Antonio
    Pudge likes this.
  26. Apr 17, 2018 at 9:39 AM
    Danimal86
    Daniel
    Sacramento, CA
    Man, for $850 just to pull the factory jbl amp.....you had better really like that factory head unit!!!!!!!!!!!!
  27. Apr 17, 2018 at 10:24 AM
    Beerdude77
    But you've been satisfied with the slim lines correct?
  28. Apr 17, 2018 at 10:30 AM
    smooosh
    Ongoing project
    TW3 are all thin line. There are no regular. They are the same ones that come in the stealth box.
    But to answer your question yes they are great.
  29. Apr 17, 2018 at 12:35 PM
    RasTafari48
    RasTafari48 New Member
    I just finished installing the taco tunes system 1b in my SR5 CM (non JBL) about 2 weeks ago. I am VERY pleased with the sound. the 2 10" Image Dynamics subwoofers are loud AF. I chose to go with ********* specifically because of the pnp and all the youtube videos showing exactly how to get the job done. I loved the fact that I didn't have to run any speaker wires from the amp to the door speakers (I hated doing this on my old Tacoma setup). once you tune the amps by following the youtube instructional video, the system sounds amazing, I sometimes feel that my rearview mirror will fall off from all the bass lol. one thing I didn't like about the package was that I thought that the modified replacement sail panels for the new tweeters were included (it's listed in the system 1b package on their website), however it was not received with my shipment. when I contacted their support team, they told me that it is not include, that they sell it separate. no biggie though, if you have a dremmel tool, you can easily modify your stock sail panels to mount the new tweeters (took me about 10 minutes for each side). they have a video on this as well. price wise, the $1599 sticker was worth it, BUT I had to pay a HUGE shipping cost. But I live in Hawaii, so we're used to paying absurd amounts of money for shipping large items. "paradise tax" I guess.
    afbatts, 4Runner, aperezsh and 2 others like this.
  30. Apr 17, 2018 at 1:47 PM
    Beerdude77
    Yeah I had the confrused...I thought we had the same sub's...sorry long day lol
