Taco Tunes vs other guys
Discussion in 'Audio & Video' started by Stumpjumper, Mar 16, 2018.
  1. Mar 16, 2018 at 10:50 AM
    Stumpjumper
    Stumpjumper [OP] Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I am trying to justify the additional cost for going with Taco Tunes vs say Amazon or Crutchfield. I put together 3 complete packages including amp and sound processor. If I use a Rockford amp the cost difference is $105 but if I go to a lower priced amp like a Rockville then the diff is $205. The differences are in sales tax - $50 (Tx only), shipping $20 (Tx), harness' - about $50. ? is how is 100% PNP worth. Taco Tunes is giving me all kind of reasons to buy theirs but the numbers don't make sense. They told me if I travel to San Antone and pay cash they will waive sales tax. I don't travel that way enough to justify the trip. They said I will void warranty by hacking up wires. I can buy a wire harness for truck side and not cut or splice anything. Not quite as clean on the other end but will work fine. I am kind of using $50 as my break point. Now the question I will I notice a difference between the Rockville and the Rocfkord amps. Just spent an unexpected $1k on new fridge so saving a little dough means somewhat more today than 3 days ago. Wondering who else has done a similar analysis and what you decided. This is a simple benefit versus cost analysis.
    GNTundra likes this.
  2. Mar 16, 2018 at 11:02 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    100% piece it together on your own! You can shop around for the right equipment for your needs and budget vs. getting whatever a company can get the best deal on, package it with a couple adapters and call it "PNP".
  3. Mar 16, 2018 at 11:04 AM
    bayfisher27
    bayfisher27 New Member
    JEFF
    2018 TUNDRA SR5
    Alpine ILX Carplay, Bedcover
    I went with ********* (system is on order now) because I like the fact they specialize on Toyota’s. I’ve used Crutchfield tech support in the past and was not impressed. And with Amazon, no tech support at all. My vote is for *********.
    GoCboys likes this.
  4. Mar 16, 2018 at 11:10 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Ok, pretend for a sec that you have plenty of wiring experience and no real need for tech support. I think Taco Tunes is well worth it for someone that might need tech support and without 100% PNP they would need to pay an installer.
  5. Mar 16, 2018 at 11:12 AM
    bayfisher27
    JEFF
    2018 TUNDRA SR5
    I totally agree! If you got the skills, you could piece together something I’m sure. I just like convienence. Good luck to you!
  6. Mar 16, 2018 at 12:31 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    My only advice would be you get what you pay for....A cheap amp, speakers,etc are going to be just that..cheap..just make a good decision based on the type of music you listen to and how you listen to it.
    Toyotoholic and bayfisher27 like this.
  7. Mar 16, 2018 at 5:06 PM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    My last Tundra I did a complete rewire and a full custom audio. From the Q logic dual 8's, new speaker wire, new head unit, soldered every connection, and full sound deadening. It was a badass '05 AC. God damn I miss that truck's sound.
    That truck got smashed in a bad accident. Gone. Dumb bitch ran a red light and I tagged her good.
    Now I have a 2016 DC and the sound was total garbage. Pretty sure all the door speakers were blown when I got it. I needed a new system. I still have all my speakers and amp from old truck, do I cut up everything and make a custom install? I opted not to do that. I went with a ********* amp, door brackets, and all their oem connectors to use the stock HU and run new speakers. I did some math and saw crutchfields options. I even cross checked some prices on sonicelectronix (FYI that place is the shit). I decided to invest in Tacotune's R&D and buy their setup. Whole deal cost me about $420. And that was without speakers because I had my own. Totally worth it. Everything worked. Everything plugged in like it was supposed to. I didn't have to remove the HU at all.
    Sure it's not going to win a contest, but it's not getting stolen because there's nothing to see. I listen to punk rock music and this system sounds great to me.
    I still need a subwoofer, haven't picked one yet. Probably going with a sealed 10 under the rear passenger bench. Cool thing, when I add the amp, it's only two wires because ********* amp rack is already prepped for it.
  8. Mar 16, 2018 at 5:24 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    The question is, what are you trying to do? Are you piecing together everything on taco tunes website? If you buy a complete system setup, let's say system 1B, it's $1600. I know that prior to learning about *********, I was looking at about 3K to 4K. For a complete system overhaul with top quality products. Not only that but, the Toyota focus they have and they are a small independant local (Texas) company. Not to mention the customer service, if you were to have an issue, would probably be better to get a replacemet part than Amazon or Crutchfield. For $50, I think that piece of mind would be worth it.
  9. Mar 16, 2018 at 5:42 PM
    signalbobby
    signalbobby New Member
    Robert
    AZ
    16 Tundra PRO & 4R PRO
    What about OEM audio +?
    sprtbkr likes this.
  10. Mar 18, 2018 at 6:03 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Without the power wire for the amp the Rockford is $259, LCI processor is $214, harness is about $16. With a Rockville total is $100 less. Also looking at the LOC6 which would knock off another $100. Not sure if the LOC6 will clean up the signal from OEM head unit. If it will I do really need an equalizer.
  11. Mar 18, 2018 at 6:09 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Sorry, for $1600 I can put together a much better system. Taco tunes is feeding me a bunch of crap about having to hack vehicle wire unless I use their stuff. This is simply not true.
    Pudge and Cfincke like this.
  12. Mar 18, 2018 at 6:11 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Well I guess you just answered your own questions. Good luck and let us know with what kind of setup you went with.
  13. Mar 19, 2018 at 3:31 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I have not decided which speakers to get. Debating whether or not to add tweaters. For sub it will probably be a shallow box 10". I need the little bit of storage space behind rear seat.
  14. Mar 19, 2018 at 3:32 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Never heard of them.
  15. Mar 19, 2018 at 4:24 AM
    TheBronze1
    TheBronze1 New Member
    Al.
    Maryland
    2017 bronze mica 1794
    bed cover, upgraded stereo system, light bar in hood and front grill, bed lights, switch back lights by step bars
    piece it together yourself the wiring is not hard to do. there are lots of helpful videos on you tube that can walk you thru it
  16. Mar 19, 2018 at 6:44 AM
    Rica25
    Ricardo
    Tulare
    I spent lot less than 1500.00 and my system rocks.....i did Memphis highs.......and designed my own box nd installed my own wiring I did one 10 inch sub Addictive audio 750 RMS and 1200 watt max and still only spent about 800.00
  17. Mar 19, 2018 at 7:43 AM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    So you made this post just to put down there system?thats all im seeing you post is how you can beat there price and quality and there lying about needing to cut up the wiring...thats not a cool thing to do IMO...
    bayfisher27 likes this.
  18. Mar 19, 2018 at 9:04 PM
    signalbobby
    Robert
    AZ
  19. Mar 20, 2018 at 4:02 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Did not start for reasons you stated. I started to hear other people's opinions and get some ideas. Are you a fan boy? Don't really care if it is cool or not. I have chatted with Taco Tunes and explained why they were not competitive on price. I gave them every opportunity to come back with something to offset. They only came back with the wiring BS.
    trayday and 17inferno like this.
  20. Mar 20, 2018 at 5:58 AM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Well im mot a fan of there stuff nor am i a boy,but ive looked at there stuff and understand the appeal of it to some and hear its a good system.
  21. Mar 20, 2018 at 6:02 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I have heard conflicting opinions. Part of reason for post.
  22. Feb 8, 2019 at 6:49 AM
    Cthulhu
    @james@tech12volts ROCKS! Quality sub enclosures with fiberglass resin reinforced interior walls, plenty of shallow mount sub options, and LOTS of options for mids / highs. Customer service is unparalleled. Full disclosure...YES, I am a fan boy!!
    Ob1, 831Tun and phogallen[QUOTED] like this.
  23. Feb 8, 2019 at 7:04 AM
    jmdwifi
    jmdwifi New Member
    Fredericksburg VA
    2018 Cement 5.7 Limited with offroad
    All chrome gone, pro grill, KC ditch light and bluetooth wireless controller.
    I put the hem audio plus in my Tacoma. It sounded much better and was plenty loud. I don't know if it was worth the money but I didn't want to cut thing and I wanted to install it quick. It was cold outside. Took a couple hours and it worked fine. They were very nice to deal with as well. Taco tunes is similarly priced and looks similar.
