Taco tunes amplifier rack on 2019 crewmax....
Discussion in 'Audio & Video' started by shawn474, Feb 11, 2020.
  1. Feb 11, 2020 at 4:59 PM
    shawn474
    shawn474 [OP] Lego connoisseur
    MoCo, Maryland
    I previously bought the taco tunes plug and play amplifier for my 2019 sr5 crewmax. I decided to buy the amplifier rack since I didn’t feel safe with the amplifier just being velcroed to the carpet and in direct obstruction of the heater vent that is down there. Does anyone have the diagram on how this is to fit? I am trying to do it without removing the seat if possible....
  2. Feb 12, 2020 at 12:44 PM
    aparker813
    aparker813 New Member
    I believe they have videos posted on their youtube page that will walk you through it. Didn't use any TT products myself so I can't offer any input there, but I can say its almost a certainty that you'll have to "remove" the seat. You should be able to just remove the 4 bolts holding the seat to the floor and tip it backward without having to fully remove it or unplug any of the harnesses attached to the seat. Make sure the seat is slid to the rear before unbolting and tipping so it will rest against the back seat, and also watch the floor mount closest to the center console so it doesn't scrape your console.
  3. Feb 12, 2020 at 1:27 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I have their amp rack in my 2016
    You really cant do it without removing the seat.
    Just remove the bolts and unhook the connectors under the seat (3 I think, maybe 2)
    Tilt the seat back.
    That will give you the room you need.
  4. Feb 12, 2020 at 2:09 PM
    shawn474
    MoCo, Maryland
    Yeah, I bit the bullet at 7am this morning and removed the seat. I think it COULD have been done without removing the seat but would have been a pain in the a$$ and probably resulted in some cut up hands and a lot of cursing. Took about 20 minutes and allowed me to run all the wires under the carpet and clean things up. Overall, I am very happy with the quality of products that I have used from taco tunes. James is obviously a great seller too. we are lucky to have this much aftermarket support from these two guys.
    purplenova[QUOTED] likes this.
  5. Feb 12, 2020 at 6:02 PM
    purplenova
    Tom
    Ohio
    So you got it all hooked up ?
    How's it sound?
  6. Feb 12, 2020 at 6:51 PM
    shawn474
    MoCo, Maryland
    Yeah it’s been hooked up since I got it.....i had already installed the stock radio, the taco tunes amplifier and replaced my door and dash speakers. I was being ocd and didn’t like the wires being exposed and the amp just laying on the floor. So I just installed the amp rack this morning.
    I used to be the guy with the ridiculous sound system and bass......this one is much more subdued. I have the kenwood ksc-sw11 under the rear seat. It sounds great to me - it doesn’t blow the doors off but it does the job for me. I am really happy with it actually.
