T4R
Discussion in 'Off-Topic Discussion' started by Stewie, Apr 6, 2017.
  1. Apr 6, 2017 at 1:16 PM
    Stewie
    Stewie [OP] New Member
    2016 Crew Max
    So after I installed my Deaver springs, I found that the springs were rubbing against my TRD exhaust. I went to the local muffler shop to get that fixed and have an X pipe installed and saw this o_O
    Law323, JC303, RussellVaughan and 2 others like this.
  2. Apr 6, 2017 at 1:24 PM
    BillE
    BillE New Member
    Billy
    2017 White Tundra Platinum
    None so far
    Man, one tire prolly cost more than the vehicle.
    Fly'n Family likes this.
  3. Apr 6, 2017 at 1:44 PM
  4. Apr 6, 2017 at 4:22 PM
    Fly'n Family
    Fly'n Family New Member
    TX / CO
    2014 CM Limited
    Good grief...:confused:
  5. Apr 6, 2017 at 4:44 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    What a colossal waste of a 4Runner.
    Thegr8punkin and CM-LENNY like this.
  6. Apr 6, 2017 at 5:02 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Nice conversation piece! LOL
  7. Apr 6, 2017 at 5:12 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Kinda digging the rubber wheel chalk E-brake. Needs a rope attached for quicker get-away.
  8. Apr 6, 2017 at 5:13 PM
    CM-LENNY
    San Diego, CA
    Hey Matt, any pics of the Deaver springs installed ?
  9. Apr 6, 2017 at 5:17 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Hoping it has a v8 or it's not going very fast.
  10. Apr 6, 2017 at 5:19 PM
    Stewie
    2016 Crew Max
    This was during install. Anything you were specifically looking for? You can also see where the springs were hitting the exhaust.
  11. Apr 6, 2017 at 5:23 PM
    Stewie
    2016 Crew Max
    I was thinking the same thing when I saw it in the bay. When they drove it out, it was definitely a 4 banger
  12. Apr 6, 2017 at 5:26 PM
    CM-LENNY
    San Diego, CA
    Thanks for that post. Was just curious if you did an over or under spring. Now I know. Did it give you about 1 inch of lift and what shackles did you use ? Thanks......
  13. Apr 6, 2017 at 5:34 PM
    Stewie
    2016 Crew Max
    I bought everything from MCM, who was great btw. The kit includes his shackles. I installed the lift and tires at the same time so not sure how much lift I got. I'm running 35" tires and measure 42.5 in the back.
    Should also add that these are the K37 HD springs. They have 400 pounds more load capacity then the standard K37s.
  14. Apr 6, 2017 at 5:44 PM
    CM-LENNY
    San Diego, CA
    Lots of variables with tire manufacture and air pressure measuring to the ground, but just measured my truck with 37's, and I am at a fat 42". If I did my math correct for the difference in tires, looks like you are about 1.5" suspension lift over stock with those springs and shackles. Thanks for the info..........
  15. Apr 6, 2017 at 6:05 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    0-60 in only 2.3 minutes!
  16. Apr 6, 2017 at 6:21 PM
    DVYota
    DVYota Super stock street truck
    South Carolina
    2014 Sequoia 2021 Tacoma
    Basically stock
    Those shocks are sexy :anonymous:
