Systems error
Discussion in '2.5 Gen Tundras (2014-2021)' started by ToyoFam2009, Mar 2, 2024.
  1. Mar 2, 2024 at 7:59 PM
    ToyoFam2009
    ToyoFam2009 [OP] New Member
    Brandon
    Hi! I turned my cruise control off while driving and then all of a sudden had the PCS malfunction lights come on, trailer brake malfunction, cruise control malfunction, and the 4 lo and hi lights flash throughout the drive as well as the ABS lights and TCS. There is no check engine light and the parking assist still works any ideas of what to replace? I had an inspection done and nothing was found. I have a hard time believing every system is malfunctioning and feel that 1 issue is causing the excess.
    thanks in advance! Pictures to come
    2018 Tundra limited crew max 192,000 miles
  2. Mar 2, 2024 at 8:03 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    A common cause of these symptoms are the wheel speed sensors.
    Tripleconpanna and 2mchfun like this.
  3. Mar 2, 2024 at 8:06 PM
    2mchfun
    Sounds like you might have a wheel abs sensor issue. Likely related to a wheel bearing failing. Jack up each corner and wiggle the wheels a little as you spin them. There shouldn't be much movement and after you have done them all you should be able to identify a difference if one is bad.
  4. Mar 2, 2024 at 8:08 PM
    2mchfun
    BTW welcome to the forum from OKC!
  5. Mar 2, 2024 at 8:15 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    2mchfun likes this.
  6. Mar 2, 2024 at 8:55 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Probably already covered (wheel speed sensor/ABS sensor), but pull the codes (full run not just 'common codes') and see what you come up with...
    Once you've logged the codes, clear them out and see if they come back on... Moisture, running through rain puddles, etc. can sometimes trigger the faults, and once the reset is done they may self-resolve. However, w/your milage, it's a good chance you've got a bad sensor....
    Good luck on a quick and inexpensive resolution and welcome to the forum :thumbsup:
    2mchfun likes this.
