Synthetic oil
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ewe, Sep 14, 2022.
  1. Sep 14, 2022 at 3:13 PM
    Ewe
    Ewe [OP] New Member
    2021 silver tundra sr5
    I had oil changed at 5000 miles on my ‘21 Tundra SR5 a while back and the guy insisted that I use synthetic oil rather than conventional oil. He said all newer Tundras are running synthetic. Any truth to this?
  2. Sep 14, 2022 at 3:14 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Can't get the 0 in 0W with conventional oil.
    I think. Nobody correct me if I'm wrong.
    Alex38, 14burrito, Black Wolf and 4 others like this.
  3. Sep 14, 2022 at 3:17 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    ^^ this
    hagrid likes this.
  4. Sep 14, 2022 at 3:21 PM
    Synthetic….
    Black Wolf, WILLINH and mav7021234 like this.
  5. Sep 14, 2022 at 3:27 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    All new Tundras have synthetic oil and have had for years now.
    whom ever did your oil change must have been a new guy or not at a Toyota dealership??
    Metro14536 and WILLINH like this.
  6. Sep 14, 2022 at 4:43 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    I didn't even know they still made conventional oil. I don't think I would use it, thinking of Royal Purple. Used in my Supercharged car that lowered my oil temps.
  7. Sep 14, 2022 at 5:26 PM
    Zolander
    Zolander New Member
    Zorro
    OffRoad
    Synthetic oil only 0W 20 is the recommended oil.
    WILLINH likes this.
  8. Sep 14, 2022 at 8:39 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    But we ALL know, synthetic 5w30 is superior on our engines...
  9. Sep 14, 2022 at 9:34 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
  10. Sep 15, 2022 at 4:07 AM
    pursuit2550
    pursuit2550 New Member
    Run what you want. Change it often. The key here is maintenance. If a mechanical part is going to fail, it will fail and no matter what oil you use will prevent that.
    HulkSmurf14 and Nightshade1970 like this.
  11. Sep 15, 2022 at 4:24 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    This.
    and drain/fill your damn Trans oil every 30k. it's easy. use valvoline maxlife ...it's cheap & good & at walmart
    has someone released the data on engine failures related to oil choice?
    has there ever been an engine oil related failure in an engine that had the proper level of oil?
    WILLINH and pursuit2550[QUOTED] like this.
  12. Sep 15, 2022 at 4:51 AM
    pursuit2550
    I don’t think there has been. At least I haven’t heard of one. 1 of the million mile tundras used dealer oil, which I am sure is just as good as the next oil but no one goes and really buys dealer oil.
    I do buy dealer trans oil. I have this feeling that the trans will fail with the MaxLife stuff. Which I know is t true since plenty of people run MaxLife.
    Cpl_Punishment and hagrid like this.
  13. Sep 15, 2022 at 4:57 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Did you read your owners manual?
    Spend the extra $5 and get the synthetic.
    WILLINH and Black@Blue19 like this.
  14. Sep 15, 2022 at 5:48 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If you can find conventional 0W-20, fill your boots.
    WILLINH likes this.
  15. Sep 15, 2022 at 6:27 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I buy the dealer air for my tires.
    Alex38, Johnmatrix, Luckydog and 6 others like this.
  16. Sep 15, 2022 at 6:29 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Is it synthetic?
  17. Sep 15, 2022 at 6:30 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    it's probably recycled....
  18. Sep 15, 2022 at 6:38 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Eww
    Bammer and hagrid like this.
  19. Sep 15, 2022 at 7:19 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I dunno? The air tank has like 16 signatures on it, so...
  20. Sep 15, 2022 at 7:30 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Op haven’t got a new car for a while… salute to OG
  21. Sep 15, 2022 at 9:25 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    For 0W20 synthetic is the only option. For any other grade, you should use synthetic. In a pinch conventional or a synthetic blend would be fine if it meets the API specs and is used for a shorter interval.
    Since this is not posted enough on here. This is straight from the Toyota Service Manual (TIS), applies to all years of the 3UR-FE from 2007-2021. And before anyone asks, Toyota is not changing the specs/design for the engines sent to Mexico. They are exactly the same.
  22. Sep 15, 2022 at 10:42 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Is there a aftermarket cooler for them?
  23. Sep 15, 2022 at 11:14 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    There will be. Alpha testing right now.
  24. Sep 15, 2022 at 11:26 AM
    Abos
    Abos Long live 5.7L V8
    2014 SR5 Crewmax
    I stopped using oil ages ago. I put used cat urine in mine. The ammonia in the urine is a great solvent for 5.7L Toyota engines.
    texasrho83 and Cpl_Punishment like this.
  25. Sep 15, 2022 at 11:37 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You can also let a little "oil" out and use it to wipe your windows
    Cpl_Punishment likes this.
  26. Sep 15, 2022 at 12:42 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I am sitting at my Toyota dealer right now. Getting the metal filter cap and Fumoto valve installed. When I requested 5W-30, was told they don't even have that weight oil in the service shop anymore...
  27. Sep 15, 2022 at 12:46 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Signature air. Nice! Mine has filtered Dallas city air. Never can get the tires to balance with it so I switched to imported air.
    Luckydog and Retired...finally like this.
