Switch
Discussion in '3rd Gen Tundras (2022+)' started by Ipaddick, Apr 17, 2023.
  1. Apr 17, 2023 at 1:10 PM
    Ipaddick
    Ipaddick [OP] New Member
    Canada
    Platinum hybrid w/advanced package
    Hey!
    Just wondering if anyone has found an oem looking switch that fits in the blank below the auto high beams (where the manual headlight level would be in some trims). Only blank switch I have, and would like to add a light bar switch there.
    Thanks
  2. Jan 17, 2024 at 3:12 PM
    2023TSS
    2023TSS New Member
    Sheldon
    2023 Tundra SR5 TSS
  3. Jan 18, 2024 at 3:33 AM
    Ipaddick
    Canada
    ryanwgregg likes this.
  4. Jan 18, 2024 at 4:09 AM
    Ipaddick
    Canada
    Hey. If it was a new switch that worked I wouldn’t complain
    ryanwgregg[QUOTED] likes this.
  5. Jan 18, 2024 at 6:14 AM
    2023TSS
    2023TSS New Member
    Sheldon
    2023 Tundra SR5 TSS
    I thought all the square switches were the same size. Must be a minimal difference.
  6. Jan 18, 2024 at 6:23 AM
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    The OEM headlight leveling switch is back loaded or mounted from behind is likely the reason an aftermarket switch doesn’t fit. Aftermarket variations are inserted into place from the front.
  7. Jan 20, 2024 at 2:36 PM
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Just ordered one from ch4x4 lots to choose from or make your own in the custom section
  8. Jan 20, 2024 at 6:19 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Or maybe we need a 3D printer guy like @raylo to make up a sleeve to fit standard size switch.
