Switch Pros 9100 Install
Discussion in 'Lighting' started by matictundra, Jun 10, 2019.
  1. Jun 10, 2019 at 10:57 AM
    matictundra
    matictundra [OP] New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Ok gals, I'm trying to figure out location and wiring for the power module in the engine bay. Please post your pix of your install, thanks.
    Pinay likes this.
  2. Jun 10, 2019 at 11:01 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Just had Switch Pro installed Saturday...no idea how he did it but excellent work!!
    zachzap361, Sunnier, 15whtrd and 10 others like this.
  3. Jun 10, 2019 at 11:12 AM
    matictundra
    Franco
    AZ
    Thanks. That side of the bay gets electrically crowded from what I've seen. I'm thinking installing it on the other, between the air box and firewall. Also, switch pro doesn't recommend power module sitting as shown because water will pool on the connector.
    porkitt and Pinay[QUOTED] like this.
  4. Jun 10, 2019 at 11:14 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Up to you I guess. Battery is on this side and all wires fished thru from engine into the cab where Switch is mounted...
  5. Jun 10, 2019 at 11:18 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
  6. Jun 10, 2019 at 11:19 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  7. Jun 10, 2019 at 11:22 AM
    sdhq_offroad
    GILBERT, AZ
    Hopefully he left enough wire length for you to get your fuse box lid off. I've seen that happen all too many times.
    Pinay[QUOTED] likes this.
  8. Jun 10, 2019 at 11:24 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I think so!! Greg does great work!
    https://www.instagram.com/greg_gm3/
    TheBeast likes this.
  9. Jun 10, 2019 at 11:27 AM
    matictundra
    Franco
    AZ
    Do you have a fuse between for the main power as recommend by Switch Pro's (SW)? I don't see one in the pix?
  10. Jun 10, 2019 at 11:32 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Let me look and see...
  11. Jun 10, 2019 at 11:36 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Does this help??
  12. Jun 10, 2019 at 12:08 PM
    TheBeast The Beach
    clean !
  13. Jun 10, 2019 at 12:10 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    And I have room to put in 5 more lights!!! :angrygirl:
  14. Jun 10, 2019 at 12:12 PM
    TheBeast The Beach
    :spending::spending:
  15. Jun 10, 2019 at 12:49 PM
    matictundra
    Franco
    AZ
    Looks like you have inline fuse?
  16. Jun 10, 2019 at 12:50 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Here is mine. Main fuse is located in the B+ cable supplied with the kit
  17. Jun 10, 2019 at 12:51 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I really am not sure. My guy Greg did the install, I trust him since he’s done a lot of setups...
  18. Jun 10, 2019 at 12:52 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Looks good Francis!
    Porschetech29[QUOTED] likes this.
  19. Jun 10, 2019 at 12:54 PM
    matictundra
    Franco
    AZ
    Thanks for the feedback. Why 150A if SP-9100 is only rated for 125A? Your fuse will never trip until SP-9100 is fried, correct?
  20. Jun 10, 2019 at 12:56 PM
    Porschetech29
    Francis
    Thats not a fuse,That’s an isolators for my dual battery setup.
    matictundra[OP] likes this.
  21. Jun 10, 2019 at 1:01 PM
    Porschetech29
    Francis
    This is the 125A fuse included with the kit
    matictundra[OP], TheBeast and Pinay like this.
  22. Jun 10, 2019 at 1:01 PM
    JDL17CM4x4
    JDL17CM4x4 Adventure Mobile
    Daniel
    Riverside, CA
    2017 White Tundra TRD 4x4
    More to Come ...
    Man your truck is coming along fast Monet! I need to get that money saved back up so i can start the mods again.
  23. Jun 10, 2019 at 1:02 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Come rob some more banks with me Daniel!! :)
  24. Jun 10, 2019 at 1:03 PM
    matictundra
    Franco
    AZ
    Got you. I didn't realize it's already included. Thanks.
  25. Jun 10, 2019 at 1:04 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  26. Jun 10, 2019 at 1:06 PM
    JDL17CM4x4
    Daniel
    Riverside, CA
    More to Come ...
    So fresh and so clean clean ......
    Porschetech29 and Pinay[QUOTED] like this.
  27. Jun 10, 2019 at 1:07 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I highly recommend Greg, he knows his lights and installs are top notch! Lemme know when you’re ready and I’ll get you his contact.
  28. Jun 10, 2019 at 1:10 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Make sure u password protect ur switchpro so no one can get a hold of ur settings thru Bluetooth
  29. Jun 10, 2019 at 1:11 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Thanks for the reminder Tony!
  30. Jun 10, 2019 at 1:12 PM
    matictundra
    Franco
    AZ
    Good idea, thanks.
