Switch Panel Labels
Discussion in '2.5 Gen Tundras (2014-2021)' started by TonyNCo, Jan 11, 2022.
  1. Jan 11, 2022 at 8:26 AM
    TonyNCo
    TonyNCo [OP] New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    6/8 gang electronic switch panels...
    Does any one know where they can be ordered with custom labels? Or a way we can create them at home?
  2. Jan 11, 2022 at 8:33 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    is this for something like a switch pro where you want partially transparent labels? What about just a label maker?
  3. Jan 11, 2022 at 9:08 AM
    TonyNCo
    Tony
    Yeah, I would love the same effect, so the backlight shows through. I think mine is Auxbeam or similar off of Amazon. One is mounted and used currently. Have a second to mount.
  4. Jan 11, 2022 at 9:10 AM
    MadMaxCanon
    Not too sure but maybe you can just order the sticker set for the switch pro from their website?
  5. Jan 11, 2022 at 9:22 AM
    TonyNCo
    Tony
    Yeah, there are several sites/brands on Amazon etc. However they are pre-made labels. The options are a lot for marine labeling. But limited for lighting, unless using the same symbol/pic... Also, to get a good supply of them, have to order double to get enough stickers. Just be nice to be able to order a custom sheet or be able to print them at home. I found similar label sizing, but not translucent. They are paperish looking stickers.
  6. Jan 11, 2022 at 9:27 AM
    MadMaxCanon
    Might be a long shot but you may be able to get something custom like that done at staples or something. I just dont think partially transparent labels are popular enough to be easily available.
  7. Jan 11, 2022 at 10:08 AM
    TonyNCo
    Tony
    Yeah, kinda what I was thinking. This is not a very big niche. Plus, ink jet printers prolly can't do it. :(
  8. Jan 11, 2022 at 10:27 AM
    MadMaxCanon
    Yeah, or you would need some crazy expensive special paper/laminate.
