Swing case
Discussion in 'General Tundra Discussion' started by Bassn429, Feb 8, 2020.
  1. Feb 8, 2020 at 1:46 PM
    Bassn429
    Bassn429 [OP] New Member
    Just ordered a swing case. Has anyone installed it using only half the bolts so you don’t have to drill as many holes. Thanks to all
  2. Feb 8, 2020 at 2:23 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I guess it depends on how much you intend to put in it.
    I used all the screws to install mine.
    If your concern is having the holes if you remove it to sell or trade the truck, I'm sure you could find some black plugs to put in the holes.
    Lowes or Home Depot sells small packages of them in the specialty hardware..
    Something like this.
    https://www.amazon.com/GOOACC-Retainer-Plastic-Fasteners-Chrysler/dp/B07L6FJGR4/ref=sr_1_34?crid=2FFZKOR4GGSOA&keywords=black+screw+hole+plugs&qid=1581200376&sprefix=black+screw+hole+plugs%2Caps%2C181&sr=8-34
  3. Feb 8, 2020 at 2:36 PM
    Bassn429
    Just hate drilling holes in my brand new truck
    1lowlife[QUOTED] likes this.
  4. Feb 8, 2020 at 2:47 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I would use all the self tappers.
    Pudge, nvrgvup444 and 1lowlife like this.
  5. Feb 8, 2020 at 3:05 PM
    Sunnier
    Sunny
    San Diego, CA
    I have one. I think you’ll see when you go to install, you should probably use all the fasteners. As it is, it’s a lot of weight on one end of the swing case.
    FirstGenVol and nvrgvup444 like this.
  6. Feb 8, 2020 at 3:07 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  7. Feb 8, 2020 at 3:11 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I was gonna grab two of these things, buuut after seeing the "trail" edition models I'm going to see if you can get those storage containers that are in the bed of the tundra from the dealer. Those are perfect for the new topper I got on order.....
    Spitfire and MotoTundra like this.
  8. Feb 8, 2020 at 4:05 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I haven't seen them yet. :monocle:
  9. Feb 8, 2020 at 4:16 PM
    Bravohook
    Addame
    NY
    2007 RCSB
    Cool Things
    These my brotha!!!
  10. Feb 8, 2020 at 4:31 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  11. Feb 8, 2020 at 5:43 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Sold! Get some part #'s! I was going to order 2 swingcases for my 2020.
    MotoTundra likes this.
  12. Feb 8, 2020 at 5:53 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    I can't imagine these cases not being compatible with earlier models unless Toyota just gone stupid.
    shellshock likes this.
  13. Feb 8, 2020 at 6:39 PM
    biebs96
    PA
    I want those cases
  14. Feb 8, 2020 at 7:23 PM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    I wonder how those install? Would love to keep my off road gear in one instead of rubbermaid bin
    ForceV4 likes this.
  15. Feb 9, 2020 at 1:41 AM
    Bravohook
    Addame
    NY
    2007 RCSB
    Cool Things
    If you search the TFL channel on youtube they made a video "The 10 coolest trucks of chicago" they mount to the truck bed using 4 bolts 3 outside and 1 inside the lockable area. Pretty sure the bottom bolts are the same that mount the bed to the frame.
    I'm gonna reach out to the dealer here, I would assume its early in the game for them to be available, but I will also reach out to Roman from the forum here and then SparksParts as well...standby to standby!!!
  16. Feb 9, 2020 at 4:06 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    What's the distance between the boxes? Can you slide a 4'x8' sheet of plywood in there?
  17. Feb 9, 2020 at 4:34 AM
    Bravohook
    Addame
    NY
    2007 RCSB
    Cool Things
    It didn't say in the video but I highly doubt you would be able to throw a sheet back there and have it lay flat. I have a crewmax and use a 12' utility trailer for any sort of "hauling" I have to do. For my needs those tubs would be perfect for me.
  18. Feb 9, 2020 at 7:04 AM
    Bassn429
    Has anyone modified the mounting bracket so u can still have your back tie down hooks ? Or won’t the box latch then. There has to be a way to do it.
  19. Feb 9, 2020 at 7:42 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    MT Madman likes this.
  20. Feb 9, 2020 at 8:31 AM
    Sunnier
    Sunny
    San Diego, CA
    The swing case wouldn’t swing, if you did this. That’s why they have to be removed.
  21. Feb 9, 2020 at 9:07 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Insulated case, Really like the idea for us grocery snatchers.
  22. Feb 9, 2020 at 9:28 AM
    Spitfire
    Spitfire New Member
    Long Island
    I would like one of those yota cases if it could be installed into bed rail and open inward.. would work great with windoors
  23. Feb 9, 2020 at 9:55 AM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    I will try to get some pictures, I grinded down the brakets some, so still have the hooks to use and the case does still swing out, if want to carry something larger I can move the swing case out
  24. Feb 9, 2020 at 10:01 AM
    don3032
    don3032 New Member
    don
    Sunnier likes this.
  25. Feb 9, 2020 at 10:09 AM
    Bassn429
    Great job that’s what I was thinking but didn’t know if it would work
    don3032[QUOTED] likes this.
  26. Feb 9, 2020 at 10:12 AM
    don3032
    don3032 New Member
    don
    Yea just grind it down enough to fit. Then spray painted it black, since the case pops in and out still get to keep both tie downs.
    Bassn429[QUOTED][OP] likes this.
  27. Feb 11, 2020 at 5:12 PM
    Bassn429
    Just installed my swing boxes today. Modified the brackets so I could keep my tie down hooks. It worked perfectly.F28E7A49-4598-4D70-9B7A-ED8C31640F9A.jpg8B081C14-F609-49B6-B105-8409A4A15030.jpg
    Bakershack and Sunnier like this.
  28. Feb 12, 2020 at 5:48 AM
    Mr.Rumzy
    Mr.Rumzy New Member
    Sunnier likes this.
  29. Feb 12, 2020 at 7:13 AM
    Sunnier
    Sunny
    San Diego, CA
    So damned expensive! But I keep replacing all the less-expensive options I’ve tried. I hit jumps at speed and they break.
  30. Mar 19, 2020 at 6:24 AM
    Ge-Minigun
    Ge-Minigun New Member
    New here and this is my first post. I have an 04 and from looking at the mount it "might" be possible to make it fit. Since you guys have it in hand do you think it's possible? Thanks
