Swing case with Extang solid fold on 14 or newer
Discussion in 'Tonneau Covers, Caps and Shells' started by shreveporttundra, Jan 29, 2016.
  1. Jan 29, 2016 at 8:45 PM
    shreveporttundra
    shreveporttundra [OP] New Member
    Anybody tried to install a swing case with a solid fold. Company says it will not work but dimensions seem to indicate enough clearance.
  2. Jan 29, 2016 at 10:33 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I bet it would. Don't see why it wouldn't.
  3. Jan 29, 2016 at 10:35 PM
    csuviper
    Broomfield, CO
    This image shows its well under the top of the bedsides.
    Looks like there is a fold up Tonneau on this one.
  4. Jan 30, 2016 at 5:18 AM
    shreveporttundra
    yeah, that is the picture I have seen. Measurements indicate it would work. I know somebody has tried it with an Extang Solid fold?
  5. Jan 30, 2016 at 6:18 AM
    Tufftruck
    Tufftruck New Member
    2015 Bronze 1794
    I have two swing cases installed and a Fold-A-Cover G4 mounted on a 2105 Crewmax. There is more than enough clearance by several inches.
  6. Jan 30, 2016 at 6:35 AM
    shreveporttundra
  7. Jan 30, 2016 at 6:37 AM
    shreveporttundra
    Can you tell me how much clearance there is from the lower lip of the bed to the top of the case
  8. Jan 30, 2016 at 2:59 PM
    Tufftruck
    2015 Bronze 1794
    The measurement from the bed floor to the top of the my case is 16.5 inches. The measurement from the top of the bedrail to the top of the case is 6.25 inches. I'm not sure I understand what measurement you are asking for "lower lip of the bed"?
  9. Jan 30, 2016 at 6:46 PM
    shreveporttundra
    Those measurements are fine. Thanks a ton.
  10. Jan 30, 2016 at 10:58 PM
    csuviper
    Broomfield, CO
  11. Jan 31, 2016 at 5:41 PM
    Tufftruck
    2015 Bronze 1794
    All this discussion has me looking at my brackets a little closer. I installed mine in May 2015, under a cover and they barely get used. The brackets are already rusting. They are coming out this Spring for PlastiDip. You may want to do something similar prior to install.
  12. Feb 1, 2016 at 2:38 PM
    shreveporttundra
    Well, I will let everyone know. Although undercover sent me an email saying it would not work, I got one coming in. Maybe, once they found it would not work on other trucks with a Extang Solid Fold they just said the same for all. The dimensions do not lie. It should work. I will post once I get the swing case in.
    TruckLife900 likes this.
  13. Feb 3, 2016 at 7:06 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Let us know the results once you get the swingcase in and installed... I may do the same as far as ordering a swing case, I also have a solid fold. They claim it will hit on the spring clamps that hold down the tonneau, I hope they're wrong in this specific case.
  14. Feb 5, 2016 at 5:18 PM
    shreveporttundra
    Swing case WILL WORK with a Extang Solid fold on 14 or newer Tundra
    csuviper likes this.
  15. Feb 5, 2016 at 5:20 PM
    shreveporttundra
  16. Feb 5, 2016 at 8:20 PM
    TruckLife900
    2013 White SR5
    NICE!
    1 thing, what about us 2nd gen's?! I have a 13'....
    What would be different?
  17. Aug 17, 2016 at 10:32 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Thankful this thread exists. I was very excited about the swing case to handle my tie downs and other crap, but then I thought about cover as I'll be doing the Extang as well. Piece of mind... priceless!!
  18. Aug 17, 2016 at 10:42 AM
    shreveporttundra
    I would advise not to get the Extang solid fold if you want to install a swing case. It does work but it is tight fit since the clamps to hold it down and fold it up sit directly on top of the swing case. I trimmed the bottom 1/2" off the clamp but I probably did not have to it is just tight. I already had the cover and I wanted a swing case. If you do not have the cover and you know you want a swing case I would get another model that does not have clamps that fold it up or clamp in down in that location.
    NewImprovedRon likes this.
