Sway bars for 2016 limited
Discussion in 'Suspension' started by scharring100, May 25, 2018.
  1. May 25, 2018 at 7:19 AM
    scharring100
    scharring100 [OP] New Member
    Houston, Texas
    2016 Tundra Limited 4X4 Crewmax
    2016 Crewmax, Bronze 4X4
    Has anyone ever installed TRD sway bars on a stock 2016 CM Limited 4X4 5.7. I would like to stabilize the ride, will be towing a Travel trailer on occasion and probably get airbags and a WDH as well. It does sway some on wide turns, overpasses etc. Is there any difficulty installing? problems with towing or without the trailer? Advantages of getting rear and front or will rear suffice. I do have some skid plates but it is not really set up for heavy duty offload. I apologize if this subject has already been covered, I searched and could not find other posts that addresses my situation. Recommendations, issues etc? Thanks for your suggestions.
  2. May 25, 2018 at 9:33 AM
    909engineer
    909engineer New Member
    2017 Silver SR5 CM
    Sway bars are great if you're staying on the pavement most of the time. They will limit your articulation if going off-road though. Installation is super easy, just make sure you have a breaker bar.
    scharring100[OP] likes this.
  3. May 25, 2018 at 1:14 PM
    Wintyfresh
    Wintyfresh New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    The installation is easy, just did mine today on my lunch break. I highly recommend a liberal application of anti-seize to all of the bolts that pass through the end-links. As 909engineer said you'll lose some articulation off-road, but disconnecting the swaybar is just a couple bolts if necessary.
  4. May 25, 2018 at 1:34 PM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    I love mine , unless you do some serious off roading you will be fine. I think its a must do mod for any tundra unless you're a rock crawler ....
  5. May 25, 2018 at 2:00 PM
    scharring100
    Houston, Texas
    99 % of my driving is paved roads, I haul a small travel trailer but having a limited and not a TRD I was wondering if I can put the TRD sway bars on my limited and for I need to go front and rear....its 4x4 if that makes a difference. Excuse my stupidity, I'm not. Much of a mechanic. The only real off road is sand and an occasional gravel country roads, because I like to go beach fishing
  6. May 25, 2018 at 2:23 PM
    Wintyfresh
    Ramona, CA
    Yes it will fit your truck. The instructions that come with it are good, the video linked below is even better. I doubt you'll ever notice the lack of articulation. In my opinion start with the rear, it makes the most difference.
    https://www.youtube.com/watch?v=cZdVjObkTLs
    Rockbox likes this.
  7. May 25, 2018 at 2:47 PM
    Easy to install as everyone has said. I love mine I have the Hellwig rear sway and I believe it works great when towing.
  8. May 29, 2018 at 7:45 AM
    scharring100
    Houston, Texas
    thanks to all, this is great info.
