Sway bar spacer / drop kit
Discussion in 'Suspension' started by neirbot, Feb 19, 2019.
  1. Feb 19, 2019 at 7:42 AM
    neirbot
    neirbot [OP] New Member
    How many here with 2-3" of lift have installed spacers to drop the sway bar closer to it's original position? Is it needed?
    Seems to me that adjustable end links would actually be the ideal solution.
    Goofinator and 831Tun like this.
  2. Feb 19, 2019 at 7:54 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Front or rear?
  3. Feb 19, 2019 at 8:03 AM
    neirbot
    Front -- and I'm really asking about the Gen 2 & 3 trucks.
    However I guess the same question could be asked about the rear for those who have them. My understanding is that the rear TRD sway bar will accomodate up to 2" of lift.
  4. Feb 19, 2019 at 8:07 AM
    15whtrd
    15whtrd Mr. Blonde
    I have 2 inches of lift in the front and have no problems with the stock location of the front sway bar. That’s the way the stock TRD pro come anyways. As for the rear you could always rotate the mounts on the rear end 90*You are pretty much aiming for the sway bar to be level with the rest of the truck.
    831Tun likes this.
  5. Feb 19, 2019 at 8:30 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I've seen the rear sway on 4+ inch lift w/o modification. I ran a front with more than 3" lift and stock hardware but I didn't like it. Camburg and/or Total Chaos make extended front links, pretty sure?
    15whtrd likes this.
  6. Feb 19, 2019 at 8:49 AM
    Yes the rear will work with 2 inches of lift....no need to rotate the brackets. I have the Readylift 3/2 and it comes with the spaces for the front. I run the TRD on the front.
  7. Nov 30, 2022 at 6:55 PM
    Goofinator
    Goofinator New Member
    Bernard
    Hey to rear ask this I was wondering this my self. Especially coming from Tacoma where it was needed. My thought that lifting the front end 3-4” the sway bar would not reach the lower control arm. To make it reach I figured you would need to collapse the front/ put under pressure
