Sway Bar Install,new clunk from rear
Discussion in 'Suspension' started by Sephon, Apr 6, 2020.
  1. Apr 6, 2020 at 5:27 PM
    Sephon
    Sephon [OP] Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    Like the title says. I installed a TRD rear sway bar today. Now when my rear suspension flexes, there is a loud clunk from the side that I’m turning into. It almost sounds like a crack noise.
    I’m assuming this is not normal. Any advice?
    TIA
  2. Apr 6, 2020 at 5:45 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Did you loose fit and torque the bolts to spec with full weight of the vehicle on the ground? If you bolted and tightened everything up in the air then dropped it down, something is binding.
    14burrito and 15whtrd like this.
  3. Apr 6, 2020 at 6:53 PM
    Sephon
    Northwest PA
    I didn’t have it up on lift. Did it all on the ground.
    Maybe need to check the torque On the bolts?
    NewImprovedRon likes this.
  4. Apr 6, 2020 at 9:32 PM
    Caveman
    Caveman New Member
    I have a 2019 crewmax and once I added a 2" lift my rear sway bar did the exact same thing. Before the lift not one noise from the rear. A couple of weeks ago I pulled the rear sway bar off and not one pop. Soon I will put mine back on and locate the noise, but know you're not the only one. It has to be in the torque specs as there isn't much there. I have been wondering about mounting it behind the axle instead of under it. I've seen a lot of people do that but not sure if it will help.
    I'll be watching in case you get it figured out
    Is your truck lifted at all?
  5. Apr 6, 2020 at 9:43 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Pics of how you installed it.
    14burrito and Tundyfundy like this.
  6. Apr 6, 2020 at 9:46 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I installed mine per instructions and torqued down to spec. Let me tell you that torquing to spec can be very crucial in any of these moving parts. Go back, verify your install and verify your torque specs using a torque wrench. Something is most likely wrong with the install. Lifted with rear and front sway bar silent as an Owl.
    Did you use the supplied bushing grease?
  7. Apr 7, 2020 at 4:00 AM
    timsp8
    NY
    Post a pic. You might have accidentally put the mounts on wrong. I’ve seen it happen.
  8. Apr 7, 2020 at 4:05 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This ^^^.
  9. Apr 7, 2020 at 5:16 AM
    Sephon
    Northwest PA
    Coachbuilder +2 in the rear lift.
    I’m going to a buddy’s now to get another torque wrench to check again.
  10. Apr 7, 2020 at 5:30 AM
    15whtrd likes this.
  11. Apr 7, 2020 at 5:31 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    You installed the u brackets incorrectly.
    https://youtu.be/cZdVjObkTLs
    Mattco808 likes this.
  12. Apr 7, 2020 at 5:36 AM
    15whtrd
    15whtrd Mr. Blonde
    Some people mount it that way if their truck is lifted. It may be hitting the exhaust as I see it’s the TRD dual.
  13. Apr 7, 2020 at 5:38 AM
    Didn't know that Sean.:thumbsup:
    15whtrd[QUOTED] likes this.
  14. Apr 7, 2020 at 5:48 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    You would typically mount the bar that way if you have lowered the rear like I have. Shortened end links are required when you lower the rear, so your long end links are probably binding in some way.
    15whtrd likes this.
  15. Apr 7, 2020 at 5:49 AM
    15whtrd
    15whtrd Mr. Blonde
    I have the pro suspension and +2 coach builders. I didn’t mount it the way he did because I didn’t feel like moving the brake lines. But at full droop my leaf springs hit the edge of the sway bar. I don’t know if I’m going to get some extended links or eventually remove the coach builders and add some spring packs.
    On that note, the only time they hit is on full flex. And I’ve never hit them just driving around corners. Which leads me to believe it must be his exhaust.
  16. Apr 7, 2020 at 6:12 AM
    Danman34
    Danman34 New Member
    Danny
    Looking at the connecting bolts, they don’t look like they are torqued properly at all. You can see the alignment is off and there is space between the bushings.
    15whtrd likes this.
  17. Apr 7, 2020 at 6:14 AM
    Sephon
    Northwest PA
    That's what it sounds like too. I re checked the torque specs and they are spot on 48 for bottom of the links, 84 on the top.
    I'll try swinging it back down to the bottom of the axle.
    Rex Kramer[QUOTED] likes this.
  18. Apr 7, 2020 at 6:15 AM
    Danman34
    Danman34 New Member
    Danny
    Look how much bolt is past the nut here. Yours looks likes it needs a few more turns.
    NewImprovedRon and 15whtrd like this.
  19. Apr 7, 2020 at 6:15 AM
    Sephon
    Northwest PA
    Sorry about that, I had loosened them just before I took the picture. Good catch though!
  20. Apr 7, 2020 at 6:19 AM
    15whtrd
    15whtrd Mr. Blonde
    It also looks like you might want to ditch that extra washer on the inside.
    Danman34 likes this.
  21. Apr 7, 2020 at 6:19 AM
    Danman34
    Danman34 New Member
    Danny
    I just noticed that as well.
  22. Apr 7, 2020 at 6:23 AM
    Sephon
    Northwest PA
    You guys rock.
    I'll pull those washers out, re torque. Take it for a spin. If that doesn't fix it, I'll try putting it back under the axle like Rex suggested.
  23. Apr 7, 2020 at 6:34 AM
    15whtrd
    15whtrd Mr. Blonde
    One thing I did when I added the coachbuilders was flip that bolt so that the nut is towards the tire.
  24. Apr 7, 2020 at 8:40 AM
    Rex Kramer
    Georgia
    I have a washer on both sides.
    15whtrd and NewImprovedRon like this.
  25. Apr 7, 2020 at 8:45 AM
    Caveman
    Caveman New Member
    Mine sounds like a Loud pop when taking a slow sharp turn or coming out a steep driveway. Is that what yours sounds like?
  26. Apr 7, 2020 at 8:46 AM
    Sephon
    Northwest PA
    That's exactly it!
  27. Apr 7, 2020 at 8:50 AM
    Caveman
    Caveman New Member
    Mine didn't start until I changed rear shocks and added rear shackles.
    I thought I messed something up with the lift but after taking it apart and rechecking everything figured it was the sway bar.
    Once I took the sway bar off it went away, but I want the bar back on...
    I'm in the exact same boat as you...
  28. Apr 7, 2020 at 8:53 AM
    Sephon
    Northwest PA
    I have the coachbuilder +2 shackles. I'm going to try a couple things this afternoon, I'll report back when I've exhausted all the recommendations in this thread.
    It pops like something is bound. I don't know for sure, but I'll find out. Hell, there are only 4 spots for it to bind.
  29. Apr 7, 2020 at 8:58 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Damn good thread going on right here. I'll keep this in mind when I pull the trigger on my sway bars.
  30. Apr 7, 2020 at 9:02 AM
    Caveman
    Caveman New Member
    One thing that a buddy recommend was to get a bottle of soapy water and spray one joint only and then drive the truck and see if it still makes the noise. If it still makes the noise spray down another joint and repeat. Once you locate the joint you can trouble shoot it easier. Might be worth a try if you run out of ideas.
    I can't wait for my new rear springs to show up so I can try again. Good luck!
