Sway bar help
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Rbtrd, Apr 2, 2017.
  1. Apr 2, 2017 at 9:09 PM
    Rbtrd
    Rbtrd [OP] New Member
    So Cal/Oregon
    2017 Tundra trd pro CM wht
    Installed my sway bar today and have a few concerns...
    1) the sway bar is touching the axle in two places and touching the rear diff cover. I dont think that is right... Went to a fabricator friend for help. We loosened, adjusted moved it away from axle n diff. But upon tightening it went back to touching in all 3 spots.
    2) Also tried to install a sway bar on a friends '13 tundra thats lifted 4". It wouldnt fit.
    Any knowledge would be great. Thank you in advance RB
  2. Apr 2, 2017 at 9:21 PM
    Seen YouTube post of install?
    GNTundra likes this.
  3. Apr 2, 2017 at 9:34 PM
    Rbtrd
    So Cal/Oregon
    Sorry duh my bad. My truck is a stock 2017 Tundra Trd Pro and a Trd sway bar
  4. Apr 2, 2017 at 9:37 PM
    niru316
    niru316 New Member
    2017 Tundra TRD Pro CrewMax
    @Rbtrd this may sound like a dumb question... and i dont have a good answer for your question... but did you have to lift your truck at all to install the sway bar? or were you able to install it with all 4 on the ground? lol hope you get an answer to your question soon! cause ill prob run into the same issue =P
  5. Apr 2, 2017 at 9:37 PM
    Rbtrd
    So Cal/Oregon
    On the ground
    niru316[QUOTED] likes this.
  6. Apr 2, 2017 at 9:39 PM
    Rbtrd
    So Cal/Oregon
    Watched a couple and rewatched while installing
  7. Apr 2, 2017 at 9:40 PM
    Got my sway bar used less than 1000miles 6" lift not touching any where
    Rbtrd[OP] and GNTundra like this.
  8. Apr 2, 2017 at 9:41 PM
    Rbtrd
    So Cal/Oregon
  9. Apr 2, 2017 at 9:41 PM
    Looks like the bar is upside down should have a decal in center that says trd w part number facing out
  10. Apr 2, 2017 at 9:43 PM
    Me?
  11. Apr 2, 2017 at 9:46 PM
    Yeah flip bar over right side to left
    65SNAKE, PR_02 and (deleted member) like this.
  12. Apr 2, 2017 at 9:52 PM
    :thumbsup:
    B I N G O was his name O !!!
  13. Apr 2, 2017 at 9:56 PM
    Rbtrd
    So Cal/Oregon
    Wow great eye. I will flip it over n see... But no sticker. Maybe my friend pealed it off??
  14. Apr 2, 2017 at 9:58 PM
    Rbtrd
    So Cal/Oregon
    You guys rock!!!! Thank you very much!!!!
  15. Apr 2, 2017 at 9:58 PM
    Hopefully the flip works for ya
    GNTundra and Rbtrd[OP] like this.
  16. Apr 2, 2017 at 9:59 PM
  17. Apr 2, 2017 at 10:03 PM
    TheBeast The Beach
    post pics and impressions when done :)
    Rbtrd[OP] and TXRailRoadBandit73 like this.
  18. Apr 2, 2017 at 10:17 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    this ^^^
    NewImprovedRon likes this.
  19. Apr 3, 2017 at 9:49 AM
    pocatello
    pocatello New Member
    I had the same issue with my Hellwig bar. Flipped it over and SHAZAM!
  20. Apr 3, 2017 at 9:51 AM
    Berettafan
    Berettafan New Member
    2017 CM
    You need that sticker! The gaudy red paint isn't enough to remind you it's a trd part!
    Crewmax Chris likes this.
  21. Apr 3, 2017 at 9:51 AM
    Berettafan
    2017 CM
    And you'll love the handling with it.
  22. Apr 4, 2017 at 9:21 AM
    Rbtrd
    So Cal/Oregon
    Flipped sway over and its all bettererer. Thanks for the help
  23. Apr 4, 2017 at 9:25 AM
    Rbtrd
    So Cal/Oregon
    As far as how it makes the truck handle....i think its helped. I wish i would have put it on my last CM Tundra. The Pro has such better suspension and only put 800 miles on it before sway install kinda hard to tell.
  24. Apr 4, 2017 at 12:59 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Yep, as much as I HATE to admit it.....me too:facepalm:
    SuperWhite20 likes this.
  25. Apr 4, 2017 at 2:22 PM
    Rbtrd
    So Cal/Oregon
    I gaurantee we aint the only ones
  26. Jan 15, 2020 at 3:05 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    I think it is upside down brother.
  27. Jan 15, 2020 at 3:21 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yup. Mine came with a sticker "THIS SIDE UP." :deadhorse:
  28. Jan 22, 2020 at 11:51 AM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Gots to advertise the TRD STICKER!
