Sway bar bolt issue
Discussion in 'Suspension' started by Papagriff, Jan 17, 2020.
  1. Jan 17, 2020 at 10:25 PM
    Papagriff
    Papagriff [OP] New Member
    2010 crewmax Sr5
    Hey everybody,
    I got my Eibach 3” lift and was installing it today in my garage and it went fine...until the drivers side bolt for the sway bar won’t line up! Help...I spent 2 hours freezing and couldn’t get it!
  2. Jan 17, 2020 at 10:26 PM
    Papagriff
    2010 crewmax Sr5
    Here is another view
  3. Jan 17, 2020 at 10:41 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    They can be a real PITA to get lined up! Try loosening the two bolts that hold the sway bar to the frame. That will give you some wiggle room to get the links lined up.
    Tundyfundy likes this.
  4. Jan 17, 2020 at 11:02 PM
    VietGuy
    VietGuy New Member
    Houston
    2019 Tundra CrewMax Cement
    Put the tires back on and put the truck on the ground. Gives the sway bar more wiggle room to line up.
  5. Jan 17, 2020 at 11:05 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Try putting the weight of the truck down and the tip above. I had a PITA trying to get mine lined up as well, putting the truck down on a jack stand under the LCA and looseing the frame mounts did the trick for me
    TRD15559 and Tundyfundy like this.
  6. Jan 18, 2020 at 12:18 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I never undo them at the end link for this reason always undo at the mounts......so I’d try undoing it at the mounts a see if it gives enough you can use a jack to for pressure up and down
  7. Jan 18, 2020 at 2:50 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Finish and torque everything else in the suspension components install skid plate last. Like Vietguy said, put back on the ground to give you some wiggle room. Loosen the sway bar bushing as well. You might need to jacks up one of the LCA to achieve the right angle for it to line up with the holes
  8. Jan 18, 2020 at 4:58 AM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Yup had to do the same. It was a pain. Hopefully someone chimes in with a simple trick!
  9. Jan 18, 2020 at 5:40 AM
    xtyfighterx
    Ty
    North Idaho
    Simple trick for next time....just un bolt the mounts not the end link.
  10. Jan 18, 2020 at 5:56 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Did you jack up the lower control arm? It's really the easiest way.
  11. Jan 18, 2020 at 6:00 AM
    bigblue14
    Craig
    Did you have to fight those going back on? I loosened mine and the ends were still difficult. Based on that it seems those mounts would be hard to align too.
  12. Jan 18, 2020 at 6:17 AM
    xtyfighterx
    Ty
    North Idaho
    Mine went right in. Just use a small jack to lift up the sway bar. Don’t loosen or take off the end link with this install no need at all. Just the mounts.
  13. Jan 18, 2020 at 6:19 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I had a bitch of a time getting my link back in. Wish I would have had some of these tips in mind when I did my suspension. Now that I think about it, I was worried that I cross-threaded mine when I put it back together... Now I don't want to have to find out.
    NewImprovedRon likes this.
  14. Jan 20, 2020 at 10:23 AM
    Papagriff
    2010 crewmax Sr5
    Thanks guys.
    I put the tires on and used a floor jack and got her all lined up!
    xtyfighterx and NewImprovedRon like this.
