Swapping Tow/Haul switch panel for Sequoia one?
Discussion in '2nd Gen Tundras (2007-2013)' started by Tuthmose, Jul 30, 2019.
  1. Jul 30, 2019 at 6:36 AM
    Tuthmose
    Tuthmose [OP] New Member
    Ron
    2011 Black Rock Warrior Crewmax 5.7L 4x4
    I’d love to replace that Tow/Haul switch bezel with something that would hold six switches instead of three and a (IMO) fairly useless pocket. So far, my searches seem to indicate that nobody makes such a thing. I wonder, though, if I might have stumbled upon a “half-way” option?
    Online Toyota parts catalogs show that the similarly-placed switch panel for Sequoias *without* any of the adjustable suspension leveling/setting options is the same as our Tundras. If that’s true, will the one *with* those options fit the Tundra too?
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-compartment-588310c040
    The Sequoia panel would provide one additional button position in place of the pocket. The “long” slot, used in Sequoias equipped with a Sport/Comfort controller, can be filled with a blank. It’s a shame that it doesn’t house a full six switch positions, but four is still better than three, and the long blank could be drilled for other buttons or indicator lights.
    Has anybody done this? Any reason it won’t work? Is there some other swap/option available that would yield five or six slots? Inquiring minds want to know . . .
    Tundradrenalin likes this.
  2. Jul 30, 2019 at 7:59 AM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    08crewmax likes this.
  3. Jul 31, 2019 at 7:54 AM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    That dash area from the Sequoia was the same only for Gen 2 Tundra through 2013. Toyota redesigned the interior for the Tundra in 2014 model and the Sequoia switch bezel won't fit.
    Greg
  4. Jul 31, 2019 at 9:58 AM
    Tuthmose
    Ron
    Yep yep - that's why I posted it only in the 2nd Gen subforum.
    I'd still really like some sort of "Factory Look" solution to hold a full six factory switches there, but this seemed better than nothing.
  5. Aug 4, 2019 at 9:43 AM
    Texas Bandit
    Texas Bandit New Member
    Amí
    Edinburg Texas
    2007 White 5.7 Tundra DC Limited 4x4
    295/70R18 Nitto Ridge Grappler Method Race Wheel NV Bronze Rigid Industries Radiance Pods Morimoto Xtorch 36” Light Bar SDHQ Pillar Light Mounts
    I added this and love it.
  6. Aug 17, 2019 at 7:05 AM
    Rengawt
    Rengawt New Member
    Tanner
    2010 Tundra Crewmax 4x4 Platinum
    Thanks to your post, I actually gave this a shot since I work in a Toyota parts dept. It fits perfect, the finish is slightly different as it has like a lined texture on the sequoia piece. Overall once installed though you can’t really tell. This is a good option to add switches in a factory looking way. The switch bezel I used was 58831-0C060 and the large blank is 55539-0C060.B0D9E0C2-A468-4DBE-B105-292C0CCCD0C3.jpg
    Poppy, omgboost, Dorks68 and 9 others like this.
  7. Aug 17, 2019 at 9:35 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Someone should use a 3D printer to make one with 6 button slots.
    PhotoNerd, 08crewmax and Pudge like this.
  8. Aug 17, 2019 at 12:14 PM
    Tuthmose
    Ron
    I'm glad it worked as I hoped. Looks great, man!
    Funny you should say that :D
    I've got a good friend working on that very thing as we speak. I ordered a Tundra switch panel and a Sequoia one (just to cover the bases) to be sent to his shop; as soon as they arrive, he's going to get on making a 3D print model with 6 factory switch positions, like so:
    I will post an update if he is successful, for those that might be interested in such a thing.
    If for some reason that turns out to be a non-starter, I'm pretty sure one could replace the horizontal blank in that Sequoia panel with a backlit laser etched plate and a toggle. Not quite the full-factory look, but still pretty clean if done right. That's my Plan B.
  9. Aug 17, 2019 at 2:11 PM
    TheBeast The Beach
  10. Oct 7, 2019 at 11:23 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Just ordered these parts.
    careyrob likes this.
  11. Jul 21, 2020 at 8:48 AM
    Roam&Reach
    Roam&Reach New Member
    2011, 5.7L V8, 4x4, Tundra SR5, Double Cab, Standard Bed
    Installed: NITRO Geared @ 5.29 ratio ARB Twin Locked WHITE KNUCKLE rock sliders ARB On-Board Air with VIAIR 2.5 Gallon Tank Custom Truck Rack (my design @ ROAM & REACH) 7" BDS lift FUEL Vector Wheels @ 18 BFGoodrich MK3 Tires @ 37 EXPEDITION 1 Rear Bumper (w/ 2 full size spares and rear winch) ICI MAGNUM Front Bumper SMITTYBILT Gen2 X20 Front Winch IKAMPER Skycamp 2.0 Roof Tent Pending Installation: KINGS Coilovers (custom) SPC UCA's QUICK PITCH Shower Tent Custom 22 Gallon Water Tank (my design @ ROAM & REACH / mounted @ OEM spare tire location) In Production: DIRT KING LCA's Custom Power Tray (my design @ ROAM & REACH / mounted over starting battery and fuse box) Custom Skid Plate (my design @ ROAM & REACH) Custom Dual Battery Tray (my design @ ROAM & REACH / mounted under the chassis); In R&D Process: Custom bracket for Dash Mount to hold Nav gear, etc. Custom brackets for my truck rack to hold Maxtraxx, Bikes, Kayaks Custom brackets for truck bed to hold fishing tube Rear-Seat drawer system (my design @ ROAM & REACH) Wish / Must List: Custom Rear Springs by DEAVER Traction Bars by SDHQ 46 Gallon Gas Tank by TRANSFER FLOW Ham Radio Dual Slide Series by CARGO EASE On-Demand shower system by JOOLCA
    Hi. So pumped i found this thread. I'm chucking my 3 switch panel. So has this 6 switch been made and available for sale now? If not, the part number for the Sequoia is 58831-0C060, correct?
  12. Jul 21, 2020 at 12:24 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    This is awesome! If nobody has made the six switch panel yet I'd be willing to make them if enough people are interested.
  13. Jul 21, 2020 at 3:06 PM
    Roam&Reach
    How much for a prototype? Would you 3D print them?
  14. Jul 21, 2020 at 6:28 PM
    careyrob
    Carey
    Massachusetts
    Interested. How much is this going to hurt?
  15. Jul 21, 2020 at 6:47 PM
    Charvonia Design
    Keith
    Huntersville, NC
    Yes I would 3D print them using black ABS.
  16. Jul 21, 2020 at 7:35 PM
    12crewmax
    12crewmax New Member
    Oscar
    Myerstown PA
    2012 Crew Max TRD
    I would be intrested in a 6 switch panel. 3D printing would be awesome. Keep is updated as to when something comes up to purchase.
  17. Aug 13, 2020 at 1:39 PM
    Krumbs2020
    Krumbs2020 New Member
    Matthew
    NorCal- Napa
    '12 Crewmax, Limited
    ARB OME 2.5" BFG KO2 Relentless Offroad bed bars, cargo rack RCI armor FullVue rearview mirror/camera
  18. Aug 13, 2020 at 8:17 PM
    The Dude
    The Dude New Member
    Chandler, AZ, not anymore :(
    I found good use for that pocket
  19. Aug 14, 2020 at 6:12 AM
    Zimms
    Zimms I suggest you let that one marinate.
    Ben
    Wisconsin
    2012 Black Tundra Platinum
  20. Aug 17, 2020 at 8:01 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    So glad I found this thread.
    I am in the early planning stages of my tundra and was looking for a clean place to mount light switches.
    I found the oem sequoia piece on eBay for $17 shipped!
    https://www.ebay.com/itm/331704755205
    does anyone have confirmation of switches that will fit right in or very close in the oem holes?
  21. Aug 17, 2020 at 8:10 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    These fit the smaller holes perfect.. not sure about the larger blank. here’s my ditch light switch installed
  22. Aug 17, 2020 at 8:25 PM
    Krumbs2020
    Matthew
    NorCal- Napa
    Rago doesn’t make those switches- and doesn’t warranty them... Buy direct from Cruiserhead4x4.
  23. Feb 8, 2021 at 9:12 PM
    NFARIDI
    NFARIDI New Member
    Any update on this?
    Krisanna79 likes this.
  24. Feb 9, 2021 at 7:30 AM
    SC_TRD
    Colin
    Round Rock, Tx
    Updated mine as well!
  25. Apr 23, 2021 at 5:32 AM
    Krisanna79
    Krisanna79 New Member
    13 crewmax tss 4x4
    Any update on the 3D part? I’ve had the same thought, just ordered the sequoia part, might take it to the kid down the street with a 3D printer. Buying one would be easier.......
  26. Apr 23, 2021 at 6:00 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    Now that's a GREAT idea.....this afternoons project.
    The Dude[QUOTED] likes this.
  27. Apr 23, 2021 at 6:10 AM
    biebs96
    PA
    I had used that area on my second gen for a screen for an aftermarket backup camera.
    PhotoNerd and Krisanna79 like this.
  28. Apr 23, 2021 at 7:19 AM
    NFARIDI
    NFARIDI New Member
    Ran out of space already with 1 switch, but I do like it. CH4x4
    Rengawt and The Dude like this.
  29. Apr 24, 2021 at 3:20 PM
    TXTundraFan
    TXTundraFan New Member
    What else from a newer Sequoia can fit our 2nd gen Tundras? Has anyone looked to see if the newer cluster/upper dash trim is a direct fit for our Trucks?
  30. May 14, 2021 at 8:49 AM
    Rengawt
    Rengawt New Member
    Tanner
    Looks Good! What color did you choose for the light color from CH4x4, amber. I haven't seen a good picture to see how well any match the factory switches until now.
