Swapping pwer mirrors for power folding mirrors
Discussion in '2nd Gen Tundras (2007-2013)' started by camu77, Feb 21, 2016.
  1. Feb 21, 2016 at 10:55 AM
    camu77
    camu77 [OP] New Member
    Robert
    2010 Crewmax Tundra
    2010 Crewmax have power& heat swapping out to limited power folding with out puddle light on them besides the switch with power fold button what else do I need to do or know before I start the swap ?? Any suggestions or tips are more than welcomed .IMG_20151213_124828978.jpg
  2. Mar 4, 2016 at 2:06 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    My 2011DC does not have the wiring in the doors for anything except mirror adjustment. You need to check on that before you buy anything.
  3. Mar 4, 2016 at 3:58 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have the limited mirrors with puddle and power fold. Everything works except those two items. Need the switch and add additional wires. That is where i stopped for now. As soon as i get the motivations and time i will try to tackle this. Don't have the info on how to wire it up. Will need to do some research.
  4. Mar 4, 2016 at 7:15 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  5. Mar 17, 2016 at 11:58 AM
    ChuckT17
    ChuckT17 New Member
    Chuck
    '08 CrewCab
    Just put new Tow mirrors on our '08.
    Wiring at the factory mirrors was 3 connectors. Left is (from upper left corner) Green, Red, Black. Right is White, Orange, Black, also from upper left corner.
    The upper section of the mirrors can be aimed as before with the switch. The lower section can be adjusted by hand. The entire mirror telescopes in and out manually. And the turn signals on the mirrors do not flash.262f18543fe403e7f35d23e0e64de67e_4b454a5ac7788bea72dc047329f866e46715ebe4.jpg
    To get the other functions to work I'll need to add wiring and change out the switch.
    Another day.
  6. Mar 18, 2016 at 12:32 PM
    ChuckT17
    ChuckT17 New Member
    Chuck
    '08 CrewCab
    So I do want to have the turn signals on the mirrors to function. How do I find a wiring diagram with detail that shows the cable to the doors?
  7. Mar 19, 2016 at 3:37 AM
    ChuckT17
    ChuckT17 New Member
    Chuck
    '08 CrewCab
    Drove the truck to check mirror aiming and such.
    These mirrors have 2 LED (?) clusters on the out edge. One for turn signal? other for Parking Lights?
    No "Puddle Lights" (would shine down?).
    Looks like I've got to take the door trim off and see how many wires and what function in the cabling there. Then get hardware to add new circuits to the mirrors from the cabling either in the door, preferable, or in the footwells.
  8. Mar 19, 2016 at 10:36 AM
    ChuckT17
    ChuckT17 New Member
    Chuck
    '08 CrewCab
    Hey, thanks!
  9. Mar 19, 2016 at 3:35 PM
    ChuckT17
    ChuckT17 New Member
    Chuck
    '08 CrewCab
    Looked for a link (as a post by you) but didn't find it.
  10. Mar 20, 2016 at 7:18 AM
    ChuckT17
    ChuckT17 New Member
    Chuck
    '08 CrewCab
    Great, got it and thanks!
    Now to wade thru.
  11. Mar 26, 2016 at 3:03 PM
    ChuckT17
    ChuckT17 New Member
    Chuck
    '08 CrewCab
    Whoa. Lots to digest there!
    I need to isolate the circuitry at the mirror (side of the connector) and figure out which is ground and which is power for the various functions. Probably best to remove a door panel and make up a set of 12v test connectors from a battery pack.
  12. Apr 3, 2016 at 2:48 AM
    ChuckT17
    ChuckT17 New Member
    Chuck
    '08 CrewCab
    The mirrors I bought have tilt and swivel motors, turn signals, clearance lights, and heaters. If they have motors to extend them or fold them I can't tell yet.
    I've been able to ID most of these connections from the wiring diagram and will try to post which wire goes where.
    I also sent an email to the vendor asking for an internal wiring diagram for the mirrors no response yet.
  13. Apr 3, 2016 at 6:50 AM
    ChuckT17
    ChuckT17 New Member
    Chuck
    '08 CrewCab
    This is the new driver's side mirror:
    This shows the two lights on the outside:
    This is the mirror extended:
  14. Apr 3, 2016 at 8:43 AM
    ChuckT17
    ChuckT17 New Member
    Chuck
    '08 CrewCab
    See if I can't figure whether there's a motor to extend/retract the mirrors by putting voltage to the connectors not identified.
  15. Apr 14, 2016 at 6:55 AM
    ChuckT17
    ChuckT17 New Member
    Chuck
    '08 CrewCab
    Wife refused to use the mirrors I had to swap them back.
  16. Apr 14, 2016 at 8:43 AM
    ChuckT17
    ChuckT17 New Member
    Chuck
    '08 CrewCab
    Haunintended consequences in this instance.
