Swapping auto level to spyders
Discussion in 'Lighting' started by graves037, Dec 25, 2017.
  1. Dec 25, 2017 at 1:52 PM
    graves037
    graves037 [OP] New Member
    Michael
    Pea Ridge AR
    16 Tundra SR5
    3" readylift, trail grapplers on 20" rockstar II's, truxedo lopro, lund bull bar, 20 & 30 in lightbars, tint, LEDs
    So my wonderful wifey got me spyder headlights for Christmas....I haven’t gotten to dive into it yet but was wondering if someone could tell me or point me in the direction of the auto leveling motor or whatever getting transferred onto them being discussed. I’m sure it’s been discussed, but I searched with no avail
  2. Dec 25, 2017 at 3:04 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Can't help you with your question. But kudos to your wife for supporting your bad habit.
  3. Dec 25, 2017 at 3:25 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
  4. Dec 25, 2017 at 6:44 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Start reading at somewhere around post 38, I gave somebody else my recommendations/instructions on how I did mine. You can't just unscrew the adjuster screw all the way, you have to unscrew them most of the way, then twist the motor to unlock it from the housing, then you can finish removing the screw. The adjustment screw is to long to be able to unscrew it all the way without unlocking the motor from the housing.
    https://www.tundras.com/threads/installed-new-spyder-drl-headlights.8822/page-2#post-324474
    NewImprovedRon likes this.
  5. Dec 26, 2017 at 6:26 AM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    I knew I’d seen talk about it too, just couldn’t find it when I needed it. Thanks guys!!!
  6. Dec 26, 2017 at 5:18 PM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    Okay new question.....how do I manually adjust these things?? The nylon nut? The bolt in the middle of the nylon nut?? Something completely different?
  7. Dec 26, 2017 at 5:22 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Bolt in the middle, I think it's a 7 or 8mm.
  8. Dec 26, 2017 at 5:23 PM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    Okay, so no turning of the nylon at all then?
  9. Dec 26, 2017 at 5:39 PM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    Are they actually a pain in the ass or am I missing something?
  10. Dec 26, 2017 at 6:38 PM
    Cuzican
    Cuzican New Member
    Louisiana
    If you are talking about these, the white nylon just holds the screw in place, you unscrew the bolt in the center most of the way, then twist these out to remove them to install the motors. If you are just trying to aim the spyders, then just the bolt in the middle, don't touch the nylon.
  11. Dec 26, 2017 at 6:52 PM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    Thank you so much!! Very very helpful
  12. Dec 27, 2017 at 8:34 AM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    Yesssss exactly!!
  13. Dec 28, 2017 at 7:10 PM
    rvl456
    rvl456 2017 SR5 TSS CrewMax 5.7L 4x4, Short Bed
    RAFAEL
    San Antonio, TX
    2017 TUNDRA SR5 TSS Texas edition
    none yet, Headlights will be 1st project
    I have ANSO Ubar headlights, I want to install LED bulbs LUMEN® H7XXHLC-G7S - G7S LED Conversion Kit (H7). Has anybody done it? Do they fit in the housing?
