Swapping a 3.4 liter for a 4.0 liter
Discussion in '1st Gen Tundras (2000-2006)' started by rxpb, Jan 27, 2019.
  1. Jan 27, 2019 at 10:02 AM
    rxpb
    rxpb [OP] New Member
    Mario
    2002 Toyota Tundra SR5
    Can you swap a 2002 Toyota Tundra SR5 3.4 liter with a 2005 Toyota Tundra SR5 4.0 liter? I was given a 2005 Toyota Tundra that was involved in a wreck. The guy that gave me the car thought it had a 3.4 liter, but it has a 4.0.
    Will the motor mount up smoothly? and would I need wiring harness and computer? and as far as California smog, would I need to take it to a smog referee for approval?
    Anyone out there have some technical advice?
    I have the complete 2005 Toyota Tundra
  2. Jan 27, 2019 at 10:11 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Different trans right?
  3. Jan 27, 2019 at 10:20 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Are the trucks apples to apples? Both 4x4? Same cab?
    Would it not be easier to take all the required parts off your truck to make the wrecked truck whole again?
  4. Jan 27, 2019 at 12:14 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    well if you have both complete trucks, in theory you should have everything you need to do a complete swap. All mounts, wiring, ECUs etc will probably need to be moved over with the engine and transmission.
  5. Jan 27, 2019 at 12:57 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I like Obx’s idea of swapping your body onto the newer truck in the damaged areas
