swapping a 2wd cab onto 4x4 chassis
Discussion in '2nd Gen Tundras (2007-2013)' started by justsmashn1, Nov 1, 2023.
  1. Nov 1, 2023 at 10:10 AM
    justsmashn1
    justsmashn1 [OP] New Member
    '07 Tundra 5.7 4x4
    Have a wrecked '08 5.7 4x4 Tundra and was wondering if I can swap a 4.7 2wd cab into it's place and if so what all has to be changed(harness, dash componets, etc)? Thanks for the help and tips.
  2. Nov 1, 2023 at 11:36 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Cab wise, probably nothing, since it's all pretty much the same. you may need to check out the wiring section for each cab 4.7 vs 5.7. I do believe you may need to swap over your dash as well as the 4x4 dial. Luckily Toyota separates the Engine ECU from the Body and components, so you may need to do minimal electrical.
    https://www.tundras.com/threads/ultimate-tundra-wiring-diagrams-collection.81448/
    justsmashn1[OP] likes this.
