Suspension weight capacity
Discussion in 'New Member Introductions' started by Fairbrother, Feb 8, 2025.
  1. Feb 8, 2025 at 4:48 PM
    Fairbrother
    Fairbrother [OP] New Member
    2025 Toyota Tundra SR5 lunar Rock color
    Hello everybody this is my first Toyota truck. It's a 2025 Toyota Tundra SR5. Lunar rock is the color. It's fantastic I really like it. But....
    I build a lot of decks and fences and I'm constantly putting a lot of weight back there. The manual says I can put like 1,960 lbs in the bed. I'd like to upgrade it somehow so I can get at least $3,000 if not 4,000 lbs in the back. Like a full pallet of concrete if need be. Any ideas or is that even possible. I know I can upgrade the suspension and shocks but how much weight extra will that give me.
  2. Feb 9, 2025 at 5:32 PM
    TVille
    TVille New Member
    TN
    2025 Gray 1794 Tundra TRD
    Congratulations on the Tundra!! I'm a new owner as well.
    You want to more than double the carrying capacity of the truck? You need a trailer. Your truck should be able to two around 11,000+ pounds. If you want to carry it in the bed, you need a Chevy/Ford/Ram HD 3/4 or 1 ton.
    While you may be able to stiffen the springs to avoid the back end squatting, it won't change the rated capacity of the truck. It won't change the rated capacity of the rear axle. Oh, and the tires probably would need to be upgraded as well.
    Fairbrother[OP] likes this.
  3. Feb 9, 2025 at 5:36 PM
    You need to ignore the manual. Look at the sticker inside the driver door jamb for your trucks payload.
    As for the absurd amount of weight you want to put in the truck, you can't load a half ton truck up to that level regardless of what you do to the suspension. It will be severely overloaded. I'm not sure you can put that much in the bed of an HD 3500 truck without overloading.
    You need a trailer.
  4. Feb 9, 2025 at 7:47 PM
    Fairbrother
    Thank you both and I agree, I think I need to get a trailer. I could tow so much more weight that way. Congrats on the new ride Tville! I just love sports mode and the way the rear window rolls down like a regular window
  5. Feb 9, 2025 at 7:52 PM
    CajunTim
    CajunTim Original Recall Engine Going Strong
    SELA
    22 Platinum CELESTIAL SILVER METALLIC Advanced Package 4x4
    DiamondbackHD, bedrugXLT, Binize, Compustar remote start, 20% all around,
    Welcome and Try Tow+ mode it’s even better.
  6. Feb 12, 2025 at 3:50 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  7. Feb 16, 2025 at 2:27 AM
    Tacoma-Tundra
    Tacoma-Tundra New Member
    Tony
    06 Tundra SR5 LTD CC 4.7 V8 AT 2WD
    Welcome from NC:hattip:
  8. Feb 16, 2025 at 3:56 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You need a bigger truck or a trailer. You can’t increase the weight capacity of the truck. That’s dictated by the frame strength. Not the suspension. Suspension plays a role, but you can’t physically add load capacity to the truck. Especially not 3,000 lbs over what it’s rated for.
    Fairbrother[OP] and texasrho83 like this.
  9. Feb 16, 2025 at 6:09 AM
    A trailer is the way to go if you have the room for it.
    I would also look into your states laws while in commerce.
    Another option would be having concrete delivered. HD has delivery services. A trailer that can handle heavy construction duties will cost you around 8-10k. That's a lot of deliveries without the heartache.
