Suspension squeaks and creaks
Discussion in 'Suspension' started by BlueRibbon4x4, Feb 1, 2020.
  1. Feb 1, 2020 at 7:49 PM
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
    Yo folks. After a pretty rough trail run, my suspension and steering squeaks and creaks over slow, bumpy terrain. Anyone have ideas on where to lubricate or check for loose connections?
    Pinay likes this.
  2. Feb 1, 2020 at 8:00 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    There aren't any suspension components to lubricate unless your removing and replacing parts. The Tundra frame is a C-channel aft of the engine and tends to flex the frame and body a decent amount. You could always check the bolts on the coilovers, leaf springs, and rear shocks but this truck will always make some noise as you go down the trail.
    BlueRibbon4x4[OP] likes this.
  3. Feb 1, 2020 at 8:04 PM
    BlueRibbon4x4
    Geno
    Ok, I understand that. What I’m wondering is that it didn’t make any noise coming up and down my dirt driveway before, but now it makes all types of noise, even while maneuvering into a parking spot.
  4. Feb 1, 2020 at 8:08 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    Once in a while I have to spray out in between the leaf springs. I'll get some gnarly squeaking and creaking if crud gets in there.
  5. Feb 1, 2020 at 8:10 PM
    BlueRibbon4x4
    Geno
    You mean with a pressure washer?
    TheBeast likes this.
  6. Feb 1, 2020 at 8:15 PM
    JimboSlice413
    Bakersfield
    Yes, hitting it with the pressure washer does the trick. But when I was looking for the noise the first time I found it by blasting in between the leaf springs with some spray lubricant, this also made the noise go away. It's happened a few times over the years but not very frequently and not every time I'm in the dirt, which is often.
  7. Feb 1, 2020 at 8:17 PM
    BlueRibbon4x4
    Geno
    Gotcha. Ok, thanks. I’ll give this a shot.
    JimboSlice413[QUOTED] likes this.
  8. Feb 1, 2020 at 8:19 PM
    JimboSlice413
    Bakersfield
    If you get under the rear wheel well and really rock the truck up and down you should be able to hear it if that's your issue. I'd do it to all 4 corners and see if you get any noise
  9. Feb 1, 2020 at 8:22 PM
    BlueRibbon4x4
    Geno
    Ok will do in the morning to check more closely.
  10. Feb 2, 2020 at 6:05 AM
    cpatts9747
    cpatts9747 New Member
    Corey
    15 tundra sr5
    I’ve been chasing a divers side creak I guess is a good describing word. I’m going to check the leafs as well. Only seems to happen first thing in the morning backing over the bump in the driveway
  11. Feb 2, 2020 at 7:03 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Uniballs? - clean, dry and lube
    Leafs? - pressure wash, lube and make sure the isolator pads are there
  12. Feb 2, 2020 at 9:44 AM
    BlueRibbon4x4
    Geno
    Ok. Will check. Thanks!
