Suspension Refresh Parts List
Discussion in '1st Gen Tundras (2000-2006)' started by _Spencer_, Sep 11, 2025 at 4:16 PM.
  1. Sep 11, 2025 at 4:16 PM
    _Spencer_
    _Spencer_ [OP] New Member
    2002 Tundra AC 4x4
    I'm planning a full suspension refresh now that the truck has proven itself (20k miles since November) with a slight lift using 5100s, OME springs, and HD leafs. I've got the majority of the parts and just ordered OEM lower control arms and all the camber bolts/nuts and I'd like any input on any parts I might be missing. I was unable to find new hardware for the UCAs so hopefully the existing hardware comes out okay.
    Here's my parts list:
    Bilstein 5100 front and rear
    KYB SM5442 strut mounts
    Old man emu 2885 springs
    JBA Upper control arms
    OEM Lower control arms
    ATS HD rear leaf springs + shackles & u-bolts
    MAXX suspension extended sway bar links
    Extended rear bump stops
    I'm unsure if I need to order insulators SM5413 for the struts or if that is included/unnecessary
    LBJs and inner and outer TREs have already been replaced. Any problems I should expect to run into or parts I'm missing? Any input is greatly appreciated.
    G_unit3000 likes this.
  2. Sep 11, 2025 at 5:00 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Looks good, same setup I just ordered. I didn’t get the leaf pack yet but in the near future. My JBA arms came in 2 days ago. Just waiting on the springs and shocks from first gen off-roading.
  3. Sep 11, 2025 at 5:06 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    That is almost exactly what I am looking at doing. I already have the springs and shocks now I want the uca and lca and a steering rack along with the suspension max end links
  4. Sep 11, 2025 at 7:28 PM
    Chris948
    Chris948 New Member
    DFW
    2006 DC
    I would order toe adjust bolts to be on the safe side. Mine came out ok but it looks like a lot of people end up sawing them off.
  5. Sep 12, 2025 at 7:52 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Not sure you're going to like these on your AC. Might be too stiff. Remember, because you have the 5100s, if you need extra lift in front, you can always adjust up on the circlips.
