suspension noise when starting up
Discussion in 'Suspension' started by SeanO86, Mar 19, 2018.
  1. Mar 19, 2018 at 7:40 AM
    SeanO86
    SeanO86 [OP] Live Slow. Die Whenever.
    2018 SR5 Tundra TRD Off Road - Cement
    Fox 2.5 w/Resis +1 CB Shackles SPC UCA Alcan 750lb springs - +1" lift 3" Front : 1.65" Rear to level Toyo ATII 35s Icon Six Speed +25 offset Wheelers Superbumps Chrome delete ARE Z Topper w/ Thule rails Pinsu Topper rack RTT - Tepui Autana Ruggedized 3
    I just purchased a new 2018 Tundra SR5 Crewmax with the TRD off Road package. I've had the vehicle 2 weeks and have been noticing a noise coming from the front suspension area...not entirely sure if the noise is suspension related, but I wanted to see if anyone else hears/feels this.
    Basically, every time I start the vehicle, put it in drive and go a couple of feet or make the first turn, there's a noticeable tick/grind kind of noise coming from the front underbelly of the vehicle. I've considered taking it in the the dealership, but I wanted to check here first to see if this is normal OR am I just being a crazy new Tundra owner babying the shit out of my vehicle?
  2. Mar 19, 2018 at 7:43 AM
    I say have someone at house video it or u video it take to dealer n show em or leave at dealer overnight see if it can be replicated
    MotoTundra likes this.
  3. Mar 19, 2018 at 7:45 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    It could be a lot of different things. The best advice I can give you is to get under there and look for yourself. I had some work done to my truck and afterwards I had a rattle which I told them was probably heat shield due to the sound. I took it to the dealership three different times and they couldn't find it. I got frustrated, looked under the truck, and found it within 30 seconds, bent it out of the way and ban! No more annoying rattle.
    Trying to diagnose noises can be really hard, especially over the internet.
    Try to narrow it down to one side or the other or the middle and then look for anything that may seem out of the ordinary if that makes sense.
  4. Mar 19, 2018 at 7:46 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    This is great advice I totally forgot I did this. I took a video of the rattle and played it for the tech, he could not believe how loud it was because he couldn't duplicate the noise.
  5. Mar 19, 2018 at 7:52 AM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    I have noticed the exact same thing on mine. Seems to be steering system related but I haven’t pinpointed it yet. It’s like a “clunk” sound to me.
    It seems it only do it then and after long sitting periods. It doesn’t seem to happen the rest of the time driving it(after the initial noise).
  6. Mar 19, 2018 at 8:02 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I have been told it is the ABS system that does a self-check every time you start the truck.
    Rextinkleton93 and Black Wolf like this.
  7. Mar 19, 2018 at 8:14 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Dealer checked mine out on the lift and I haven’t heard it since. Mine is aftermarket though
  8. Mar 19, 2018 at 8:28 AM
    Steve6
    Steve6 New Member
    Tucson
    I've noticed that if my truck hasn't been driven for a few days, it will make a momentary grinding noise when I turn on the heat / AC. Probably not related but you never know.
