Suspension noise after lift
Discussion in 'Suspension' started by Sniperinhisname, Jan 2, 2021.
  1. Jan 2, 2021 at 3:15 PM
    Sniperinhisname
    Sniperinhisname [OP] New Member
    Danny
    California
    2020 Tundra Platinum 4x4
    I recently lifted my 2021 tundra with a complete arb ome lift with 700 springs with a dv8 bumper with winch and now I have a squeak/creak/pop coming from my front passenger side. I've went over it twice and tightened every bolt I touched, removed the skid plate and the sway bar and it's still there. It happens when I turn the wheel all the way like when backing into my driveway. It also happens when I hit a speed bump it will make the noise with the wheels straight. I only hear it at low speeds. Any ideas? I've been reading for a while and cant find anything
  2. Jan 2, 2021 at 3:18 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Did you tighten the lower control arm bolts.
  3. Jan 2, 2021 at 3:25 PM
    Sniperinhisname
    Danny
    California
    Cranked the shit outta them
  4. Jan 2, 2021 at 3:31 PM
    What are you running for wheel and tire setup? What offset? What size lift? Still stock UCA's? Just trying to determine if you may have any rubbing issues on the body mount, the UCA's, back of the bumper, etc.
  5. Jan 2, 2021 at 4:03 PM
    Sniperinhisname
    Danny
    California
    Ome 2.5 with 700 springs. SPC uca's, method nv305 with +24 offset, toyo mt 35x12.50r18, cab mount chop. Aftermarket bumper. Definitely not rubbing anywhere I believe
  6. Jan 2, 2021 at 4:38 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Did you put an impact gun on them? Reason I’m asking is cause I had a popping noising when turning my tires left or right after an alignment was done. Ended up being that.
  7. Jan 2, 2021 at 4:58 PM
    Sniperinhisname
    Danny
    California
    Na big ass breaker bar lol
  8. Jan 2, 2021 at 7:28 PM
    Hambone1
    Hambone1 New Member
    Blaine
    2015 tundr limited
    Not much yet
    I had a Jeep that did that one time with 6 inch lift.....ended up being a bolt to long and was rubbing when going over speed bumps straight or when wheels were locked out
  9. Jan 4, 2021 at 1:20 PM
    Sniperinhisname
    Danny
    California
    Anyone else have any ideas?
  10. Sep 16, 2021 at 3:24 PM
    mesquitetundra
    mesquitetundra New Member
    2020 Smoked Mesquite Tundra Limited TRD Off- Road
    did you ever figure out the issue?
