Suspension lifts
Discussion in 'Suspension' started by kchap, Oct 1, 2021.
  1. Oct 1, 2021 at 8:00 AM
    kchap
    kchap [OP] New Member
    I bought a 4.5in bds coilover lift and it calls for replacing the crossmember. From anyones personal experience would cutting the oem crossmember off and replacing it with the bds crossmember negatively effect the truck in any way other than possible trade in value?
  2. Oct 1, 2021 at 10:19 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Once you cut it, you can’t go back to stock. There are other kits out there that don’t require cutting the frame.
    Black Wolf likes this.
  3. Oct 1, 2021 at 10:31 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I would say yes, but much of that can depend on the potential buyer. I personally would not buy a truck with a cut crossmember.
    No real need for a lift like that considering you can fit 35s/37s with 3 inch coilovers. But vendors sell 4-8 inch lift that cut the crossmember, so folks out there buy and install them because they like the very high look.
    Bottom line, don't expect the lift to add value when you sell and it will deter some buyers, but could attract others. As Dan said, once it is cut, it is cut.
