Suspension lift or leveling kit
Discussion in 'Suspension' started by smallcooper150, Nov 24, 2016.
  1. Nov 24, 2016 at 4:56 PM
    smallcooper150
    smallcooper150 [OP] New Member
    Cooper
    Reno
    2003 toyota tundra V8 4.7
    New kenwood stereo
  2. Nov 24, 2016 at 4:58 PM
    Suspension- but please get from a reputable source (vendor) who specializes in this in case a question arises
    FlashCulprit and Wvmoonshiner like this.
  3. Nov 24, 2016 at 5:00 PM
    smallcooper150
    Cooper
    Reno
    New kenwood stereo
    Why the suspension
  4. Nov 24, 2016 at 5:01 PM
    IMO- better ride; more adjustability to your fitting
    zcarpenter92 and Wvmoonshiner like this.
  5. Nov 24, 2016 at 5:13 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Suspension. Better ride, and more travel.
    T-Rex266 likes this.
  6. Nov 24, 2016 at 5:33 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Suspension.
  7. Nov 24, 2016 at 7:41 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Spacers limit your shock travel, making the ride harsher and impacting offload performance. Lowest cost to "level" without spacers would be Bilstein 5100s on front and coach builder shackles in back.
  8. Nov 24, 2016 at 7:46 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Suspension lift gives a better ride than spacers.
    Checkout the options at Toyteclifts.com. Vendor on here that I have used a lot.
  9. Nov 24, 2016 at 8:30 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I have 3" LRO spacers and rear shackles and the truck rides just like stock. Keep in mind I don't do any off-roading. If I did I would also recommend coilivers.
  10. Nov 24, 2016 at 8:43 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Spacer lifts are like a padded bra whereas suspension lifts are like larger ta tas.
    FlashCulprit likes this.
  11. Nov 24, 2016 at 8:51 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    This times 5 million. You pay a little more out of pocket but you're increasing the capabilities, longevity, and overall quality by huge amounts.
    zcarpenter92[QUOTED] likes this.
  12. Nov 24, 2016 at 8:53 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Plus, your chances of wearing flat-brimmed hats will go down by at least 85 percent.
    FlashCulprit[QUOTED] likes this.
  13. Nov 24, 2016 at 11:21 PM
    smallcooper150
    Cooper
    Reno
    New kenwood stereo
    So say after installing a lift kit on my truck that's about 3" and i put on 33s will that have an effect on my gearing or steering or anything else
  14. Nov 24, 2016 at 11:39 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Suspension. I don't think you'll notice much difference with 33s. It's only about 1" taller than a stock 275 65 18 . It's the width that's really different, about 1.75" and that may affect steering to a small degree, wider turning radius etc. No re-gearing is necessary.
