Suspension for 2018 Tundra CM trd off road?
Discussion in 'Suspension' started by BE Tundra, Jan 9, 2019.
  1. Jan 9, 2019 at 8:52 PM
    BE Tundra
    BE Tundra [OP] New Member
    2020 TRD PRO CM super white
    Wanting to put 33" tires the on my new Tundra was looking into the Bilstein 6112 fronts and 5160 rears but didn't know if I would need new spring for the front or what? Any recommendations on any setups for accommodating 32-33" tires? Thank you
    OR18TRD likes this.
  2. Jan 9, 2019 at 8:56 PM
    You’ll fit 33” fine on stock
  3. Jan 9, 2019 at 9:04 PM
    BE Tundra
    Yea but I'm looking to level off the truck not sure if I want to do the leveling kit, but more of a small suspension lift or different suspension adjustsadj to level it off. Any ideas?
  4. Jan 9, 2019 at 9:32 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    If you’re just looking to level your truck, with a “small” suspension lift, get bilstein 5100s.
  5. Jan 10, 2019 at 4:54 AM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    1.9 is level I believe
  6. Jan 10, 2019 at 7:22 AM
    aminter0
    aminter0 New Member
    Andrew
    2017 White Tundra CM SR5 TRD
    1.9” setting on the Bilstein 6112 coil over will level your truck. That coil over also included springs. You can buy them preassembled and all you do is swap your current set up for the new one, or you can utilize your old top hat of the coil over and save a little bit of money.
    I personally have this set up, along with the Bilstein 5160 in the back. I’m running Toyo RT 275/70/18 which is 33.2”. I did not have to do the body mount chop, but I did have to remove the front mud flap or whatever it’s called.
    Good luck!
  7. Jan 10, 2019 at 4:42 PM
    BE Tundra
    Yea that sounds great I just wasn't sure if I needed the new springs as well but sounds like I do need it. So if I just put those 6112s on the front at 1.9" and just leave the back the same but put in the 5160s should be level. I appreciate your help and input just bought my first 2018 Tundra crewmax trd of of road in cavalry blue.
  8. Jan 10, 2019 at 4:57 PM
    BE Tundra
    With the 5160 reservoir do need to order a special bracket to hold those in a correct spot or what? Are those 5160s usable on the front or just the rear? Thanks for your help guys.
  9. Jan 10, 2019 at 5:06 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    you can mount it however you like but Bilstein also sells a reservoir mount if you don't have a spot in mind
  10. Jan 10, 2019 at 10:17 PM
    aminter0
    aminter0 New Member
    Andrew
    Congrats on the new purchase, how exciting!
    The 5160 includes the piggyback mount/bracket and that is it. I would imagine they sell a mount for remote mounting, but not sure what the benefit would be. They’re designed to mount to the shock itself, so why reinvent the wheel? Lastly, the 5160 is made for rear mounting only, and the 6112 is made for front only. Hope all this info helps!
  11. Jan 11, 2019 at 8:15 PM
    BE Tundra
    How does the 5160s compare to the stock shocks for towing and payload squat?
    Rica25 likes this.
