Suspension Creak
Discussion in 'Wheels & Tires' started by jkyle92083, Nov 10, 2019.
  1. Nov 10, 2019 at 2:06 PM
    jkyle92083
    jkyle92083 [OP] New Member
    Jacob
    2019 So Slow TRD Pro
    I replaced the stock 18” wheels on my ‘19 TRD Pro with 20s. Now, at 20k miles, I’m hearing a pretty bad creaking noise from the suspension. Is this a definite effect of the larger wheels? If so, what’s the solution (other than reverting back to stock)?
    Rica25 likes this.
  2. Nov 10, 2019 at 4:26 PM
    Check the torque on the wheels?
    Rica25 likes this.
  3. Nov 10, 2019 at 4:33 PM
    jkyle92083
    Jacob
    I have not, but the dealer recently rotated them so that might be the problem. Thanks.
    Rica25 likes this.
  4. Nov 10, 2019 at 4:39 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Also check the TRD skid plate.
    Rica25 likes this.
  5. Nov 10, 2019 at 4:44 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Bed bounce? Coming when you hit bumps? Leaf spring bushings at the shackles
    Rica25 likes this.
  6. Nov 10, 2019 at 5:17 PM
    jkyle92083
    Jacob
    Low speeds over bumps. Does not occur over flat surfaces.
    Rica25 likes this.
  7. Nov 10, 2019 at 5:21 PM
    Professional Hand Model
    Hand Protectors
    Spray some PB Blast’r on your front lower control arm bushings.
  8. Nov 10, 2019 at 5:36 PM
    styx
    styx New Member
    Larry
    Knoxville, TN
    2017 SR5 DC TRD Offroad Magnetic Grey
    Raptor OEM Nerf Bars Leer Hard Tonnaeu Weathertech Vents Driver assist handle
    Could be that the cab is misaligned on the frame. Saw this happen once on a new truck. Cab was off center and after the mount was worn enough, it's bolt would rub the frame. Sound was like a dry control arm bushing creaking. Was noticeable moving slow over a speed bump or just climbing into the truck. Dealership realigned cab and installed new mounts. Worth a look see if all else fails.
    Rica25 likes this.
  9. Nov 13, 2019 at 1:38 PM
    jkyle92083
    Jacob
    Well, lubricated and checked for loose bolts. No resolution. It sounds more and more like the driveshaft or perhaps steering. Shit idk.
    Rica25 likes this.
  10. Nov 17, 2019 at 4:57 PM
    jkyle92083
    Jacob
    Update: Problem solved, ended up being rubbing between the skid plate and the frame. Loosened the two rear bolts and wedged rubber between the plate and the frame. I used an old bicycle tube I had lying around. Worked, no more creaking. Found it on this post:
    https://www.tundras.com/threads/popping-noise-in-front-end.21679/
    T-Rex266 likes this.
  11. Aug 10, 2020 at 9:55 AM
    Capt. Trips
    Capt. Trips New Member
    Utah
    2020 TRD Pro
    None. Yet.
    3E4E6C9F-7FA1-4A6C-BB2E-A539EC33273E.jpg Same issue here. My Toyota tech dug a little deeper and found this. The cause of the spacing issue. Over torqued at the factory.
  12. Aug 12, 2020 at 5:14 AM
    bowhunter_2
    bowhunter_2 New Member
    2020 Cement Tundra SR5
    What is that?
    AggiePhil likes this.
