Surging issue
Discussion in '2nd Gen Tundras (2007-2013)' started by kcgiffin, Aug 9, 2023.
  1. Aug 9, 2023 at 1:45 AM
    kcgiffin
    kcgiffin [OP] New Member
    Keith
    2010 rock warrior
    I have a 2010 Tundra with 5.7 engine that runs like a top until you put it under a load. I pull a two horse trailer a fair amount and going at highway seed I get a surge in power. You can feel the pulsating and see the RPM drop by one or two hundred and then pick up. To continues when accelerating slowly but if you step on it hard it stops surging. Trailer can be empty or loaded same thing. Any idea what it could be?
  2. Aug 9, 2023 at 3:38 AM
    Not sure when it's under a load, but a dirty throttle body will cause surging rpm's.
  3. Aug 9, 2023 at 6:32 AM
    2mchfun
    Try to run a couple of cans of Berryman's injector cleaner through a half tank of fuel.
  4. Oct 31, 2023 at 6:06 PM
    kcgiffin
    Keith
    2010 rock warrior
    Cleaned the throttle body and MAF sensor and that did not cure the surging. I will get some Berryman and try that. Any other suggestions?
  5. Oct 31, 2023 at 7:04 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Do you have a pedal commander installed by chance? If so, I would uninstall / remove it and see if that cures the problem
  6. Oct 31, 2023 at 7:07 PM
    Could it be transmission related? Check the fluid level? Ever drain and fill?
