Surging at low speed low throttle?
Discussion in '2.5 Gen Tundras (2014-2021)' started by polymerhead, Nov 6, 2018.
  1. Nov 6, 2018 at 4:32 AM
    polymerhead
    polymerhead [OP] New Member
    So, kind of a weird thing happening with the Tundra in my driveway. My driveway is about 30’ long and at a pretty good angle - call it 25 degrees. I usually pull in off the street, wait for the garage door to go up and then pull into the garage. Often, the Tundra will start to pull slowly into the garage with light throttle, and then after a few feet it will surge a bit, almost like I’m blipping the throttle, but I’m not. I don’t know if it’s a torque converter thing or a transmission thing or a traction thing - it could literally be slipping on all the tire cleaner that’s on my driveway, I don’t know. My Tacoma never did this, and my 5.0 Mustang had enough torque to climb up my driveway with no throttle. But this is my first full size truck.
    Anyone else noticed anything like this? 6k miles on the truck, been doing it since new.
  2. Nov 6, 2018 at 4:34 AM
    timsp8
    NY
    These trucks have that yaw sensor thing. Maybe the truck is expecting a steeper angle and tries to compensate?
    Where are you in MO? I’m from the boot heel, but moved away years ago.
  3. Nov 8, 2018 at 8:35 AM
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    I have the same thing in my 2017 SR5 4X4.
    polymerhead[OP] likes this.
  4. Nov 8, 2018 at 11:18 PM
    TTund16
    TTund16 New Member
    Search the site. I recall seeing a thread about it. I think I've noticed that once or twice at a stop sign uphill ... Very very short throttle surge or a pulse! Nothing out of control...
