Superdave’s lift installs, mechanic, service SoCal
Discussion in 'California' started by Superdave1.0, Feb 15, 2025.
  1. Feb 15, 2025 at 11:31 PM
    Superdave1.0
    Superdave1.0 [OP] New Member
    Dave
    LX470, 2025 Civic Si
    Hey Tundra enthusiasts.
    I'm Dave. I do lift installs, mechanic work, lighting, body armor, just about anything. I don't weld, rebuild diffs or rebuild transmissions. I love working on Toyota trucks and have owned a bunch of them. I've owned 5 4runners, a 3rd gen Tacoma, GX470 and now LX470. I've built up a good reputation on Tacomaworld for doing quality work and I treat everyone's truck like my own. Let me know if you guys need any installs or mechanic work, I'd love to help. I use 98% snap-on tools, and I firmly belive in using a torque wrench.
    I'm located in the city of Lakewood.
    Install services:
    - Lift kits
    - Sliders
    - Bumpers
    - Skids/armor
    - Roof rack/awning
    - Exterior & interior mods
    - Sound systems (woofers, etc)
    - Intake/exhaust/performance
    - Lighting (ditch lights, light bar, wiring)
    Mechanical services:
    - Free inspections/once over
    - Engine / Transmission service
    - Timing belt / Water pump
    - Suspension work/overhaul/service
    - Brakes
    - Power steering
    - Alternator & starter
    - Differential service
    - Electrical repairs/diagnosis
    - Fluid changes (oil/trans/coolant/ps/diffs/tcase)
    - Just about any service. I don't rebuild transmissions/diffs.
    TW install thread:
    https://www.tacomaworld.com/threads/superdaves-lift-installs-mechanic-service.682299/
    tlakeTundra and CappyKD like this.
  2. Feb 15, 2025 at 11:37 PM
    Superdave1.0
    Dave
    Had the pleasure of installing a nice lift kit on a Tundra this weekend. Bilstein 6112, 5160 and JBA UCA'S. Assembled the 6112 on my Branick wall mounted spring compressor.
    20250215_151933.jpg 20250215_151944.jpg 20250215_163652.jpg 20250215_160042.jpg 20250215_191038.jpg 20250215_184737.jpg
  3. Feb 20, 2025 at 10:42 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    nice work!
    Superdave1.0[OP] likes this.
  4. Feb 23, 2025 at 6:59 PM
    Superdave1.0
    Dave
    Finished the suspension on this 2.5 gen Tundra. Coach builder shackle install, carrier bearing drop and more. The shackles are beefy! Pressing out the bushings on rear leafs was easy on one side, very difficult on the other. Pressing the second side damaged the press tool, since it took so much force to remove.
    20250223_110347.jpg 20250223_110403.jpg 20250223_123315.jpg 20250223_140633.jpg 20250223_125509.jpg
    des2mtn and Nicklovin like this.
  5. Feb 23, 2025 at 7:22 PM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    Great work by Dave as usual! He’s big on tacomaworld where he’s done a ton of tacos and 4Runners, he’s a salt of the world type of good guy who is super meticulous and he’s an actual mechanic as his day job, he’s one of the few people I trust to touch my rigs
  6. Mar 4, 2025 at 9:58 PM
    Bajaguy
    Bajaguy New Member
    This might sound like a paid ad lo but Dave helped me out big time. I ran into a CV issue working on a lift on my 3rd gen Tundra and he came by to help me out and finish the job. Dave is a standup guy and I would trust him to do any work on my Tundra. If you need any work done I wouldn’t hesitate to use him at all if you’re in Socal.
  7. Mar 4, 2025 at 10:00 PM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    I know Dave personally and he’s a salt of the earth genuine good dude rare trait these days
    Superdave1.0[OP] and Bajaguy like this.
  8. Mar 4, 2025 at 10:03 PM
    Bajaguy
    Bajaguy New Member
    Agreed. In these times where it’s so easy to see negative in the world Dave shows that there are still genuinely good people out there.
  9. Apr 13, 2025 at 4:57 PM
    Superdave1.0
    Dave
    Single cab Tundra was over for maintenance. Oil change and coolant flush. Someone had doubled up 2 different crush washers on the oil drain plug. Luckily I stock several different oem drain plugs.
    I also did a Tundra TRD pro full skid plate install, but forgot to take pics. :facepalm:
    20250405_134354.jpg 20250405_135923.jpg 20250405_140859.jpg 20250413_165652.jpg 20250405_145422.jpg
    tlakeTundra, des2mtn and Bajaguy like this.
  10. Jun 16, 2025 at 4:33 PM
    Superdave1.0
    Dave
    RCI front bumper install on this Tundy! Wired in some Diode Dynamics SS3 Fog lights to go with. I have these fogs on my Land Cruiser, they are very bright and SAE approved, don't blind oncoming traffic.
    20250616_121858.jpg 20250616_123739.jpg 20250616_121924.jpg 20250616_140222.jpg
    bulldog93, Bajaguy and des2mtn like this.
  11. Jun 18, 2025 at 8:23 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
  12. Jun 18, 2025 at 6:46 PM
    Superdave1.0
    Dave
    Ok ok. Is T-150 better?
  13. Jun 19, 2025 at 2:23 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    Yes, of course
    [​IMG] [​IMG]
