Supercharged Tundra.
Discussion in 'Performance and Tuning' started by Rockstar72, Nov 27, 2019.
  1. Nov 27, 2019 at 5:40 PM
    Rockstar72
    Rockstar72 [OP] New Hampshire in the house
    Kris
    Manchester, NH
    2020 Army Green Toyota Tundra TRD Pro Crewmax
    Looking at a supercharged 2015 Tundra. Do they come from the factory like this?
  2. Nov 27, 2019 at 6:07 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    No, superchargers are an aftermarket addition, though Toyota made TRD superchargers (built by Magnusson) to add to their 5.7L engines.
    ColoradoTJ likes this.
  3. Nov 27, 2019 at 6:18 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    TRD SC was discontinued is 2015, but by then then or earlier it could be an official Toyota add on. But this time though, it is irrelevant as a 2015 is beyond warranty.
  4. Nov 27, 2019 at 6:24 PM
    Rockstar72
    Kris
    Manchester, NH
    Are they reliable?
  5. Nov 27, 2019 at 6:24 PM
    How many miles on that 15? Does seller know when it was installed? If seller had it installed...by whom....?
  6. Nov 27, 2019 at 6:31 PM
    4Runner
    4Runner New Member
    Columbia, SC
    No clue but see no reason why. I’m only 20k in though.
  7. Nov 27, 2019 at 6:35 PM
    Rockstar72
    Kris
    Manchester, NH
    146k. One owner. I'm going to look at it Friday.
  8. Nov 27, 2019 at 7:45 PM
    When was it installed?
    Black Wolf likes this.
  9. Nov 27, 2019 at 7:54 PM
    Hard to give a recommendation. Hell, we have a member that's installing a SC on a 275K+ mile Tundra.
    Kerch71 likes this.
  10. Nov 27, 2019 at 7:57 PM
    Or, get screwed with it as Toyota won’t warranty it. You’re not original owner. Was it purchased and installed by Toyota? If so, when?
  11. Nov 27, 2019 at 8:02 PM
    This guy speaks from experience...FYI
  12. Nov 27, 2019 at 8:20 PM
    Rockstar72
    Kris
    Manchester, NH
    I'll have to find out about all this. I've only looked at it on cars.com. It looks to be in excellent shape.
  13. Nov 27, 2019 at 8:35 PM
    ZPMAN
    Minnesota
    21,000$ not to bad.
  14. Nov 27, 2019 at 9:07 PM
    KTM Hauler
    KTM Hauler New Member
    Rich
    Santa Clarita
    2017 SR5 Tundra 4x4
    Method 306 18"x9" Nitto Ridge Grapplers 275/65r18 Leveling kit
    It looks like the owner took pretty good care of it, looks clean.
  15. Nov 27, 2019 at 10:37 PM
    00PS
    00PS New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    Yeah clean from the outside but people who have superchargers aren’t likely to go easy on the skinny pedal.
    OP not to deter you, but you sound like you’re just getting your feet wet. I recommend you look over everything inside and out with a fine tooth comb. Collect as much information as possible from the owner and 3rd parties such as Carfax. If not having done your homework, this could be an unexpected money pit.
    KTM Hauler[QUOTED] likes this.
  16. Nov 28, 2019 at 2:51 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    That truck looks nice Kris. Do you know the maintenance history?
  17. Nov 28, 2019 at 3:06 AM
    Kerch71
    Mechanicsville VA
    Mine has 50k miles on it, just had it on a dyno and zero drop in performance. I'd say they're pretty reliable. Oh, and they're fun as hell.
    AZTundra likes this.
  18. Nov 28, 2019 at 3:27 AM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    You may want to verify how many miles are on the SC. I'm heavily into researching the Magnuson for myself and will install one in the near future.
    There may be some maintenance due on the SC. I don't have a definitive answer yet but "believe" the SC has to be removed to be serviced (oil changed in it). This video confirms you have to "yank the supercharger off" but he attempts the oil change without doing it:
    https://www.youtube.com/watch?v=_NkYCCvaoRM
    Supercharger Belt / Part Number / Frequency changed
    "The drive belt would be changed just the same as a factory drive belt, which is around 60,000 miles."
    "For the systems we sell ourselves, we recommend that the supercharger oil is changed every 80,000 miles (Eaton specs the oil for 80-100,000 miles)"
    https://www.tundratalk.net/threads/definitive-supercharged-maintenance-guide.233169/
  19. Nov 28, 2019 at 11:19 AM
    ZPMAN
    Minnesota
    Because of the location and hard to visually see the plug I would set my phone on Smart View then set it the proper position along with my 32" TV thats on the work bench. I belive you could pare it to another phone also.
    Racingjohndeere55 likes this.
  20. Nov 28, 2019 at 11:51 AM
    4Runner
    4Runner New Member
    Columbia, SC
    This is what I got from Magnuson late last year.
    Spark Plugs. Denso IKH 22 - every 30k
    Belt Part # 79-08-11-024[Dan Bronsten] Yep that is our part number. The Dayco part number is 5081125, just in case you want to price shop. We are not the cheapest on belts.
    SC Fluid/Oil - only after leak[Dan Bronsten] , correct the oil is self-contained and maintenance free. It would be very rare to have a leak.
    Intercooler - every 100k[Dan Bronsten] , yes. Whenever you change the engine coolant. I would check the level of this fluid in the reservoir every oil change. That way you can make sure there are no leaks in the system at the various hose connections.
    ZPMAN likes this.
