Sunroof rattles anytime cover is open - Need Fix!
Discussion in '2.5 Gen Tundras (2014-2021)' started by M3Tundra-JK, Mar 12, 2023.
  1. Mar 12, 2023 at 10:29 AM
    M3Tundra-JK
    M3Tundra-JK [OP] New Member
    Scott
    2005 GX470
    Anytime I pull back the cover to expose the sunroof, I get horrible rattling noises over any kind of bump. Stupidly annoying! Pretty sure it's coming from the plastic/rubber linings on the same side that are supposed to prevent wind noise.
    What's the fix?!?!
    https://youtube.com/shorts/sAgt38TBe5M?feature=share
  2. Mar 12, 2023 at 6:54 PM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    Sorry don't have a sunroof so no first hand experience. I saw in another thread there was a problem with wind deflector but yours involving the shade only when open couldn't be that.
    Did you mod your exhaust? Engine note sounds really good.
  3. Mar 12, 2023 at 7:08 PM
    M3Tundra-JK
    Scott
    2005 GX470
    just got done with installing a supercharger. And the exhaust is currently stock, but dumped under the truck instead of side exit. Stock tailpipe wouldn't fit after I lowered truck
    2WD[QUOTED] likes this.
  4. Mar 12, 2023 at 7:26 PM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    No idea what the fix is, but something is definitely wrong. Mine is completely silent.
    I'd be going back to wherever you bought it and telling them to fix it since you're still in warranty!
  5. Mar 12, 2023 at 7:30 PM
    2WD
    2WD New Member
    Just thinking out loud - have you tried pressing the sun shade against the roof when there is a rattle and see if it stops? Can you do this when it's in the open position? Are you certain it's the shade rattling or some other part (maybe the rail it slides on?)
  6. Mar 8, 2025 at 5:27 PM
    eric06gen1
    eric06gen1 New Member
    2006 Tundra TRD
    I have this issue and I’ve definitely determined it’s the Rail that the sunroof slides on that is rattling against the glass, mainly on bumpy road/dirt roads. What would be the solution for this?
  7. Mar 10, 2025 at 5:31 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
    My Rav4 had this problem. I replaced the seal per "The Car Care Nut's" recommendation and it solved the problem. Not sure if your Tundra might be experiencing the same issue. https://www.youtube.com/watch?v=Ey4ZN-qNIBs
    HulkSmurf14 likes this.
