Sunroof questions
Discussion in 'General Tundra Discussion' started by Luiyo17, Feb 1, 2022.
  1. Feb 1, 2022 at 12:32 PM
    Luiyo17
    Luiyo17 [OP] New Member
    2014 tundra limited
    Headlights,fog lights leds. Sound system
    My 2014 tundra sunroof just works when ever, or when it works starts closing and stops halfway I have to wait a little and finally closing it. I stop even using it just in case it doesn't close completely. Any one have the same problem or something? Any recommendations so i can go and verify. Fuse is good
  2. Feb 1, 2022 at 1:56 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    open it and look at the openings and tracks. Make sure they are good and clean, no dirt, leaves or anything that would cause friction or impede movement.
    And lube the tracks! lubing those tracks/rails is normal maintenance so often missed and if they need lube they can act up, work slowly, hang, etc.
    https://www.youtube.com/watch?v=U7nYvBOuWAY
  3. Feb 1, 2022 at 2:16 PM
    Luiyo17
    2014 tundra limited
    I'll verify that, thank you
