sunroof leaking, but won't open.
Discussion in 'General Tundra Discussion' started by tiguetx, Apr 30, 2024.
  1. Apr 30, 2024 at 8:42 PM
    tiguetx
    tiguetx [OP] New Member
    MT
    2004 Tundra
    I've removed the motor and I'm shopping for repair/replace options. In the mean time, i'd like to open the roof manually, so i can clean the drain lines. Can I simply manhandle it to tilt and then forcibly make it slide open? If I do, will I be able to force it closed again? I just bought this truck and the sunroof may not have been used for years. if i park it on a slope with the front end higher, it doesn't leak, so i suspect the front drains are clogged. $549 for a replacement motor doesn't sound like something I'd be interested in. Just need to manually open it once a year to clean the drain lines. anyone know the procedure for manually opening and closing this thing?
  2. Apr 30, 2024 at 10:33 PM
    What model of 2004 Tundra do you have?
  3. May 1, 2024 at 4:37 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  4. May 1, 2024 at 5:54 AM
    tiguetx
    MT
    2004 Tundra
    @2004 SR5 157k miles, runs like new, The roof leak needs attention, fixing the sunroof, not so much.
  5. May 1, 2024 at 5:56 AM
    Assuming a double cab with factory sunroof?
  6. May 1, 2024 at 6:11 AM
    tiguetx
    MT
    2004 Tundra
    Yes and Yes
  7. May 1, 2024 at 6:24 AM
    2mchfun
    One can always silicone the leak path for a few dollars.
  8. May 1, 2024 at 7:06 AM
    tiguetx
    MT
    2004 Tundra
    I haven't given up hope of making the sunroof functional again, down the road. I appreciate the suggestion, but hoping for an answer to my question. Can I manually open and close the sunroof with the motor removed.
    2mchfun[QUOTED] likes this.
  9. May 1, 2024 at 7:08 AM
    With the motor removed, you should be able to manually open and close the roof. Just push it open.
  10. May 1, 2024 at 10:14 AM
    tiguetx
    MT
    2004 Tundra
    The last thing the sunroof does when closing is pop up in the back to seal. I’d need to push down the back to get it to the slide track. My concern is there’s a lever somewhere in the picture that might not like that much force.
  11. May 1, 2024 at 11:13 AM
    cran2
    cran2 New Member
    Folly Beach, SC
    07 Crewmax 4x4 and 03 Sequoia 4x4
    Should be able to unscrew the the glass from the track from the inside, then lift the glass up and out
  12. May 1, 2024 at 12:09 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
  13. May 1, 2024 at 12:31 PM
    tiguetx
    MT
    2004 Tundra
    Thanks, that's the way I'm leaning. I stopped by the service dept and asked about forcing the sunroof open in it's current lifted position and he also believed forcing the glass down onto the track in order to slide it might break something.
