Sumo Springs
Discussion in 'Towing & Hauling' started by TwistedTad, Jun 4, 2019.
  1. Jun 4, 2019 at 1:41 PM
    TwistedTad
    TwistedTad [OP] TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    I have 1.5 inch shackles on my Tundra. I do tow a 5,500 pound boat with a 550 pound tongue weight. I was wondering if Sumo Springs would work. I am looking for something to help with rear sag and rear support while towing. Thanks!!!
    saybng likes this.
  2. Jun 4, 2019 at 1:51 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    I was just told to get air bags versus Sumo,..I load up the bed on our trips a few times a year including trips to construction site with tools etc.
  3. Jun 4, 2019 at 2:22 PM
    neirbot
    neirbot New Member
    I use Sumos for that exact purpose (Nautique 230 boat) and they work perfectly. I also have 1.5" shackles -- just call Supersprings and have them make you new brackets to compensate for the added height of your lift.
    OBXTundra likes this.
  4. Jun 4, 2019 at 4:33 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    Thanks @neirbot !!! I have a Axis A22. How do the Sumo’s ride unloaded? Any change in ride? I will give them a call and see what they say.
  5. Jun 4, 2019 at 4:43 PM
    neirbot
    neirbot New Member
    Glad to help. Absolutely no change in ride when unloaded. There is about a 0.5-0.75" gap between the sumo spring and the frame when the boat is unloaded. That gap closes when I load the boat.
  6. Jun 4, 2019 at 5:10 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    Thanks again @neirbot !!! Seems like an easy upgrade for towing!!!
  7. Jun 10, 2019 at 3:52 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    I ordered my SumoSprings @neirbot . They are making me a custom bracket to accommodate the 1 1/2 rear lift at no extra charge.
  8. Jun 10, 2019 at 4:35 PM
    Bigboitundra
    Bigboitundra New Member
    2018 tundra crewmax
    7 inch lift
    I suggest airbags with onboard air compressor....
    Will work great and stop that back end sag
  9. Jun 10, 2019 at 5:34 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    Thanks @Bigboitundra . I am going to try the SumoSprings and see how they work. They have a 30 day return policy. If the SumoSprings lack in performance I will definitely go the airbag route. Thanks again!!
  10. Jun 10, 2019 at 6:43 PM
    Bigboitundra
    2018 tundra crewmax
    7 inch lift
    Cool let me know how they work I'd be interested...also
    What are you going to be towing?
  11. Jun 10, 2019 at 6:45 PM
    TwistedTad
    Tad
    Canyon Lake, CA
  12. Jun 10, 2019 at 6:53 PM
    Bigboitundra
    2018 tundra crewmax
    7 inch lift
    Nice.. Hopefully works out for you..
    They are alot cheaper then having to buy the airbags and compressor
  13. Jun 10, 2019 at 6:57 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    I will do an update on this post and my build thread when I get them installed and do a little towing.
    Black Wolf and saybng like this.
  14. Jun 22, 2019 at 1:50 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    SumoSprings installed!!! They were able to make me a custom spacer to accommodate the 1.5 inch rear lift. Probably going to hook up the boat this week and see how they do.
    georgiey22, Winning8, bgdv1 and 4 others like this.
  15. Jul 29, 2019 at 4:20 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    Here is a couple of pictures of my boat hooked up to the Tundra with the SumoSpings. It still has a little sag but not as much a before the SumoSprings. The SumoSprings definitely helped with the sag and a better all around ride quality while towing or under a load. A lot less rear bounce and better rear handling and control. When not towing or under a load they do not contact the frame and you do not even know they are there. I think the SumoSprings are a good alternative to airbags.
  16. Jul 29, 2019 at 9:00 PM
    Bigboitundra
    2018 tundra crewmax
    7 inch lift
    Nice truck and boat!
  17. Jul 29, 2019 at 9:55 PM
    TwistedTad
    Tad
    Canyon Lake, CA
  18. Jul 29, 2019 at 10:37 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    How do the sumo springs feel when you hit a bump at speed? Is it like hitting a bumpstop quicker? How much can the tundra compress them?
  19. Sep 16, 2019 at 12:30 PM
    TundraTRD5300
    TundraTRD5300 New Member
    2017 Tundra TRD
    2inch Leveling Kit
    Nice truck! Do you have a lift/leveling kit installed? If so, what company did you go with? I'm asking because I had the sumo springs on my last truck which had a leveling kit. I took them off and put them on my current Tundra with a 2.5/1.5 lift. Wondering how it's going to handle. Thanks!
  20. Sep 16, 2019 at 12:43 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    @TundraTRD5300 I have the Toytec Boss kit set at 3/1.5. I did the install myself. I contacted SumoSprings and they were able to make me a set with a 1 inch spacer to accommodate my rear lift. Rides and handles great either empty or towing.
    TundraTRD5300 likes this.
  21. Sep 16, 2019 at 2:22 PM
    TundraTRD5300
    2017 Tundra TRD
    2inch Leveling Kit
    Sorry for the off subject question - But did the lift or Sumo Springs effect the collision sensor in front? I've read that lifting or leveling may throw off the calibration of the sensor. Thanks!
  22. Sep 16, 2019 at 3:58 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    @TundraTRD5300 neither the lift nor the SumoSprings affected the sensors. I did keep an inch of rake for that reason. So my rear sits an inch higher than the front.
  23. Dec 26, 2019 at 10:14 AM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    I just finished installing mine and there is no gap, they are always in contact with the frame. Ima waiting to see if it makes the ride to rough when not towing
  24. Dec 26, 2019 at 12:23 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    @aussieaarons
    When unloaded it rests on both sides or just driver?
  25. Dec 26, 2019 at 12:36 PM
    aussieaarons
    Both sides, not much weight- could slide a credit card across but definite contact
  26. Dec 26, 2019 at 12:38 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Dang. Maybe your springs are flattened more than average? Hard to imagine on such a new truck
