Sulastic suspension
Discussion in 'Suspension' started by Kevincmonaghan, Dec 30, 2016.
  1. Dec 30, 2016 at 9:16 AM
    Kevincmonaghan
    Kevincmonaghan [OP] New Member
    Kevin
    Greeley, CO
    2013 CM Limited
    i searched and only found one thread about these weird shits. Does anyone on here have any experience with them? I'm tired of my wife bitching about how rough my TRUCK is..
  2. Dec 30, 2016 at 9:24 AM
    You must live were there is a ton of concrete roads.
    I have a buddy that runs them on his F350 and loves them. He travels from southern CO to Northern CO every day and he had to do something. This took care of the "chop" or hopppng feeling from the rear.
  3. Dec 30, 2016 at 9:32 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Never even heard of 'em. God I learn something new on this forum everyday. Yesterday I learned about zerks.
    NewImprovedRon and ColoradoTJ like this.
  4. Dec 30, 2016 at 9:49 AM
    Now these shackles will not help if you have worn suspension parts...mainly shocks.
  5. Dec 30, 2016 at 9:51 AM
    Kevincmonaghan
    Kevin
    Greeley, CO
    2013 CM Limited
    I only have 11,200mi on my 2013, so everything is basically brand new. I just took off my BAM race exhaust because the truck was "too loud" so now I have to fix the ride because the TRUCK is too bouncy...... I'm seriously contemplating selling it. It's not worth the head ache lol!
  6. Dec 30, 2016 at 9:52 AM
    TXMiamiFan
    Jose
    You can always get a new wife :rofl:
  7. Dec 30, 2016 at 10:05 AM
    Kevincmonaghan
    Kevin
    Greeley, CO
    2013 CM Limited
    I've weighed my options. Suspension is cheaper! Lmfao!
    rons23, Achuop, Backslider and 3 others like this.
  8. Dec 30, 2016 at 10:07 AM
    It is a truck, she realizes that right?
    My 14 longbed Tacoma rides awesome in comparison to my old Tundra. Hell, my 1 ton GMC rides better.
    There are some options:
    ToyTec makes some good kits that will make your truck ride great. There are other systems as well.
    Rear shocks are a must. I put on Bilstein 5160's and the Bilstein 6112 system up front and it was great.
    If you have Load Range E tires, that isn't helping either.
    T-Rex266 and NewImprovedRon like this.
  9. Dec 30, 2016 at 10:33 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Just get some quality shocks. Move to a 2.5 diameter shock in the rear and you will see a night and day difference in ride quality. Pretty much eliminates the bed bounce.
    What you are looking at is just a "band aid" fix that will eventually wear out itself.
  10. Dec 30, 2016 at 10:43 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Even if you get rid of the wife, you'll still lose half the truck, so that's not an option. If it's bed bounce, try throwing a couple hundred pounds in the bed, maybe some sandbags. To see if it helps, and also as a temporary solution for your wife until you decide what to do. Are you on stock non TRD suspension?
    ColoradoTJ and T-Rex266 like this.
  11. Dec 30, 2016 at 10:59 AM
    TXMiamiFan
    Jose
    Truck bounces too much, what could be wrong with that? . . . :D
    rons23, driverdog, MT Madman and 12 others like this.
  12. Dec 30, 2016 at 11:04 AM
    Never even heard of that brand. There are some great shocks out there that'll soften up the ride. Just depends what you want to use your truck for, what you'd like to (ideally) spend etc
    ColoradoTJ likes this.
  13. Dec 30, 2016 at 11:06 AM
    Oh that is so true!! Ha ha. Wise man you are sir.
    NewImprovedRon likes this.
  14. Dec 30, 2016 at 12:27 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    If she has a car, tell her she can follow you everywhere lol
    TXMiamiFan likes this.
  15. Dec 30, 2016 at 12:51 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    From what I've seen I wouldn't change a thing on that truck!
    AnonVet likes this.
  16. Dec 30, 2016 at 5:20 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    I looked into the sulastic shackles. From what I learned they don't make them for second and third gens because the leaf eye is under the frame. They only work on trucks that have the spring off to the side of the frame. I've got the Toytec shackles and bilstein 5160's. Smoothed it out quite a bit, but the bounce is still there. David at Coachbuilder claims that his shackles make a much bigger difference than toytecs because they are billet and don't flex. I'm not sure about billet for shackles though. Seems like with steel, the flex is a good thing. What would happen if you hit something, wouldn't aluminum snap when pushed beyond it's limit? Where the steel would bend and not leave you with a separated spring. David's shackles are super beefy, would have to ask him if he has tested their shear strength.
  17. Dec 30, 2016 at 7:47 PM
    209TRDPRO
    209TRDPRO New Member
    2016 Tundra TRD PRO
    Just lights for now
    I've got TRD PRO and today I put in CB +3 Shackles and 2 Shims in the front and it is smoother than before. Bed is level out with the truck also.
  18. Jan 1, 2017 at 6:59 AM
    Kevincmonaghan
    Kevin
    Greeley, CO
    2013 CM Limited
    My truck is already level, if I got +1 shackle and poly bushings, would it be worth the investment as far as ride quality goes?
  19. Jan 1, 2017 at 7:09 AM
    Kevincmonaghan
    Kevin
    Greeley, CO
    2013 CM Limited
    Also, with the +1 is anything else required? Driveline spacer, etc. (Other than the poly bushings)
  20. Jan 1, 2017 at 7:24 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I got the I got the carrier bolt spacer just in case...not really sure at what point it is necessary, but for $12 I figured WTH
  21. Jan 1, 2017 at 7:26 AM
    Kevincmonaghan
    Kevin
    Greeley, CO
    2013 CM Limited
    True, $12 is cheap insurance
  22. Jan 1, 2017 at 7:53 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The Toytec shackles smoothed out my ride some but the concrete highways are brutal. Still have bounce. What does help is weight in the bed. Try 200 lbs in the rear of the bed.
  23. Jan 1, 2017 at 8:02 AM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I stopped my Toytec shackles down to the one inch position yesterday to get the rear back to 1.5. The airbags lifted it up 1/2 inch.I noticed that they have twisted a bit. The springs aren't parallel to the frame. They make their shackles straight just like the factory. I wonder if coach builds his differntly to compensate for that. If so that might help smooth things out more by reducing the binding up.
  24. Jan 1, 2017 at 8:12 AM
    csuviper
    Broomfield, CO
    CB shackles are straight too just like factory
    To change geometry you would have to cut out and weld a new front hanger.
  25. Jan 1, 2017 at 8:28 AM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I've heard speculation that the fact that the engineers decided to put the springs splayed out could be why our trucks get the bounce so bad. Maybe they should've put kidney belts in the seats!
