suggestions on a good FOAM CANNON!
Discussion in 'Detailing' started by hi_rawb, May 24, 2018.
  1. May 24, 2018 at 8:25 AM
    hi_rawb
    hi_rawb [OP] New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    i bought the Sun jo pressure washer and cane with a foam cannon.. I used it 3 times and the 4th time I used it it took a shit on me the (foam cannon that is).. . so just wondering what good ones are out there? Thanks in advance
  2. May 24, 2018 at 8:27 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  3. May 24, 2018 at 8:37 AM
    War Machine
    War Machine SSEM # 5 3MW
    4x4_Angel likes this.
  4. May 24, 2018 at 8:45 AM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
  5. May 24, 2018 at 8:50 AM
    Danimal86
    Daniel
    Sacramento, CA
    I keep meaning to try cheap shit soap with it. I've been using CG snow foam, but its expensive so i probably only put 1/4 of a cup in the bottle and the rest water. It definitely needs a lot of soap to get that really thick foam.
  6. May 24, 2018 at 9:45 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've got this one too, works well with my electric pressure washer.
  7. May 24, 2018 at 9:49 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Damn, you guys are gonna cost me money. :eek::spending:
    Fester, or anyone, do you know the specs on your electric pressure washer? Mine is 1.6gpm at 1900psi, IIRC, just wanting to know that it is enough before I buy.
  8. May 24, 2018 at 10:09 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Off the top of my head I want to say it's 18-2000psi, 1.4gpm maybe. I know it was under the specs they list but I figured for $20 I'd give it a shot and it worked fine.
  9. May 24, 2018 at 10:10 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Thanks! Pretty comparable, I’ll have to give it a go with mine.
  10. May 24, 2018 at 10:18 AM
    War Machine
    landphil[QUOTED] likes this.
  11. May 24, 2018 at 10:25 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  12. May 24, 2018 at 10:29 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  13. May 24, 2018 at 10:34 AM
    hi_rawb
    rob
    Bay Area
    2018 Trd Sport
    I have this one
  14. May 25, 2018 at 7:51 AM
    briarpatch
    briarpatch New Member
    If you're referring to CG Honeydew Snow Foam, it's only expensive if you're buying it in 16oz bottles.....they sell it in a gallon size and it's fairly reasonable at around 30.00 a gallon. I watch for sales on it at places like Autogeek and Autopia. Of the less expensive soaps out there, I've gotten decent foam from Meguiars Gold Class. If you're using an electric power washer (like me), swap out the standard orifice (1.25mm) for the smaller one (1.1mm) in the foam cannon. Will produce better foam for you. They're available at Detailed Image
  15. May 25, 2018 at 12:48 PM
    Riskyguy
    Riskyguy New Member
    Stewart
    2018 Tundra SR5 Crewcab
    I put one in my cannon and I can't get anything out of it now. I may have to drill a larger orifice in it.
  16. May 25, 2018 at 7:12 PM
    briarpatch
    Check the filter before you drill out the orifice...or just go back to the standard 1.25. Just out of curiosity, what is your water to soap ratio?
  17. May 25, 2018 at 8:16 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    I have the MTM PF22 I won in a raffle and love the thing. Has a very high operating pressure and puts out some THICK foam.
    Voyagermike likes this.
  18. May 25, 2018 at 8:52 PM
    Riskyguy
    Riskyguy New Member
    Stewart
    Where is the filter?
  19. May 26, 2018 at 10:45 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Money spenders.... this is all i see in my future:spending::spending::spending::spending::spending:
    boostedtrdpro likes this.
  20. May 26, 2018 at 11:21 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Another vote for the cheap Amazon one. I've used mine many times, it's definitely paid for itself. I agree that I don't see any reason to pay for the expensive ones. I use Meguiars Gold class in it also. I started out using 5oz of soap and it worked awesome. I have since cut that in half and it still produces nice, thick foam.
  21. May 26, 2018 at 11:30 AM
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    Loving my CG Torq foam cannon. Got it on sale with a gallon of the honeydew snow foam. :thumbsup:
  22. May 26, 2018 at 11:34 AM
    briarpatch
    Tundra Fan likes this.
  23. May 26, 2018 at 8:43 PM
    Riskyguy
    Riskyguy New Member
    Stewart
  24. May 26, 2018 at 9:05 PM
    Shaggypeach
    Shaggypeach New Member
    Check out obsessed garage on youtube. He has a ton of content for gear.
    4Runner likes this.
  25. Jun 12, 2018 at 2:38 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Love Matt on OG. He goes high-end on everything so just adjust to your budget/objective.
  26. Jun 13, 2018 at 3:33 PM
    4Runner
    4Runner New Member
    Columbia, SC
  27. Jun 13, 2018 at 6:26 PM
    briarpatch
  28. Jun 13, 2018 at 6:55 PM
    boostedtrdpro
    Jeremy
    I have the same exact MTM PF22 and I use a 2550 psi 2.3 gpm gas pressure washer. Works awesome.
  29. Jun 13, 2018 at 6:56 PM
    4Runner
    4Runner New Member
    Columbia, SC
    Okay. Running a Ryobi but using a fancy wand from Obssessed Garage which I believe has a smaller orifice. I have since ordered an upgraded pressure washer that ups my GPM and pressure but the smaller orifice will keep the pressure around 1200 to 1100. Hope this helps.
  30. Jun 14, 2018 at 4:46 AM
    briarpatch
    The orifice is in the foam cannon itself, not the wand
