Suggestions for struts
Discussion in 'Suspension' started by spellman90, May 6, 2022.
  1. May 6, 2022 at 12:19 PM
    spellman90
    spellman90 [OP] New Member
    I cannot seem to locate front and rear loaded struts for my 2010 Tundra SR5 TRD Crewmax 5.7. Everything seems to be backordered with no date in site. Does anyone have any suggestions where I could locate them
  2. May 6, 2022 at 1:00 PM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Do you have an sr, sr5, trd sport, trd off road, etc? Are you looking for the OE shocks or something that may be a slight upgrade for longevity or better performance off road? Lift or no lift? I run the bilstein 5100's front and rear.
    For front pre assembled there are tons of non OE options. I've used bilsteinlifts.com to order and had good luck, looks like they have stock there. The yellow 4600's are what would come factory on a trd off road, no lift. I dont see an option to have those sent with new coils.
    https://www.bilsteinlifts.com/produ...toyota-tundra/shocks-07-and-up-toyota-tundra/
  3. May 6, 2022 at 1:20 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    struts? tundras don't have struts. shocks & springs. get the aibach stage 1 kit and be done with it.
  4. May 6, 2022 at 1:57 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    First post needs a hearty welcome. Hearty welcome to the forum. We likey pixs of rigs too.
