Sudden shaking and loss off power while driving
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tiamat, Mar 8, 2021.
  1. Mar 8, 2021 at 5:24 AM
    Tiamat
    Tiamat [OP] New Member
    2015 tundra crewmax xp
    So this morning while at 70 mph on highway going up a slight hill the truck started to shake and lose power. Almost felt like a loose tire or something, but the slow loss of power was evident. The mpg display went from 16 to 9 then after coming to a stop at my exit it come back up. I work very near the exit so i could check to see if it was intermittent or not. Any ideas.
  2. Mar 8, 2021 at 1:24 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Damn, that could be many things. But, I would start with the fuel pump. Is the CEL light coming on?
  3. Mar 8, 2021 at 1:27 PM
    timsp8
    NY
    Shaking sounds like something in the driveline. Check that your lugs, diff bolts, u joints are on and tight. Could you have run over something?
  4. Mar 8, 2021 at 2:19 PM
    Tiamat
    No lights, the engine rev perfect. Almost felt like the the abs had kicked on.
  5. Mar 8, 2021 at 2:29 PM
    Tiamat
    I had filled up the tank last night
  6. Mar 9, 2021 at 6:08 AM
    Tiamat
    Well while driving to the dealer it started again i could hear a clicking rear left . Sure enough i can smell brake pad. Im thinking either a stuck ebrake or a stuck caliper.
  7. Mar 9, 2021 at 10:58 AM
    timsp8
    NY
    Or possibly a damaged wheel speed sensor.
  8. Mar 9, 2021 at 11:53 AM
    Tiamat
    Well the best part is that it is covered under my warranty so they are fixing it for free.
